Asus K55VD RAM Replacement
    • Power off the device completely
    • Flip the device over to its back cover.
    • Use the switches to release the battery from its adapter.
  1. Asus K55VD RAM Replacement, RAM: step 2, image 1 of 1
    • To access the compartment that holds the RAM, flip the laptop so the bottom cover is facing upward and the battery compartment is facing away from you.
  2. Asus K55VD RAM Replacement: step 3, image 1 of 1
    • Use a Phillips #0 screwdriver to remove the two screws that hold down the compartment cover.
  3. Asus K55VD RAM Replacement: step 4, image 1 of 1
    • Lift the cover and locate the green and blue RAM sticks on the right side of the device.
  4. Asus K55VD RAM Replacement: step 5, image 1 of 3 Asus K55VD RAM Replacement: step 5, image 2 of 3 Asus K55VD RAM Replacement: step 5, image 3 of 3
    • To remove the green RAM stick, push outward on the inner sides of the two metal chip holders simultaneously.
    • Pull out the stick once it is released from the holders.
    • Repeat this step on the lower level that holds the blue RAM stick.
4 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 341
All Time: 2,488
