Asus K55a-si50301p USB 3.0 Replacement
  1. Asus K55a-si50301p USB 3.0 Replacement, Battery: step 1, image 1 of 1
    • Press and slide the two battery retention clips on either side of the battery towards the unlock position.
  2. Asus K55a-si50301p USB 3.0 Replacement: step 2, image 1 of 1
    • Pull the right side retention clip so that the red indicator is showing.
    • The small graphic below the retention clip denotes locked and unlocked positions. The clip will stay put once moved into position.
  3. Asus K55a-si50301p USB 3.0 Replacement: step 3, image 1 of 1
    • Pull the retention clip on the left hand side of the laptop away from the battery.
    • Gently pull the battery out with your free hand.
  4. Asus K55a-si50301p USB 3.0 Replacement, USB 3.0/Audio Ports: step 4, image 1 of 1
    • Remove the eight Phillips #0 screws.
  5. Asus K55a-si50301p USB 3.0 Replacement: step 5, image 1 of 1
    • Gently pull towards yourself and up to remove the first plastic cover.
  6. Asus K55a-si50301p USB 3.0 Replacement: step 6, image 1 of 2 Asus K55a-si50301p USB 3.0 Replacement: step 6, image 2 of 2
    • Use the iFixit opening tool around the outside line where the top of the laptop meets the bottom to separate components.
  7. Asus K55a-si50301p USB 3.0 Replacement: step 7, image 1 of 1
    • Flip the laptop over and lift the keyboard tray gently towards the screen.
    • Remove the 3 ribbon cables from the motherboard end.
  8. Asus K55a-si50301p USB 3.0 Replacement: step 8, image 1 of 1
    • With the keyboard tray out of the way, remove the tape holding down the accessory board ribbon cable.
  9. Asus K55a-si50301p USB 3.0 Replacement: step 9, image 1 of 1
    • Pull the ribbon cable out of its slot on the USB/Audio port board as shown.
One Comment
after doing this start button lights up but will not boot
David Garside - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 714
