Asus MeMO Pad 7 (ME572C) Battery Replacement
  1. Asus MeMO Pad 7 (ME572C) Battery Replacement, Rear Panel: step 1, image 1 of 2 Asus MeMO Pad 7 (ME572C) Battery Replacement, Rear Panel: step 1, image 2 of 2
    • Make sure your device is turned off. Then with a plastic opening tool, carefully remove the back panel by carefully working your way around the perimeter.
    • The panel will be glued on and requires pressure to open.
  2. Asus MeMO Pad 7 (ME572C) Battery Replacement: step 2, image 1 of 3 Asus MeMO Pad 7 (ME572C) Battery Replacement: step 2, image 2 of 3 Asus MeMO Pad 7 (ME572C) Battery Replacement: step 2, image 3 of 3
    • After removing the rear panel, use a plastic openning tool to remove the frame of the tablet.
    • Start in the middle of the top side and insert a plastic opening tool between the screen and the frame.
    • Carefully run the plastic opening tool along all the edges of the tablet.
  3. Asus MeMO Pad 7 (ME572C) Battery Replacement: step 3, image 1 of 1
    • When you take the rear panel and the frame out, place the rear panel and the frame away from the device.
  4. Asus MeMO Pad 7 (ME572C) Battery Replacement, Battery: step 4, image 1 of 3 Asus MeMO Pad 7 (ME572C) Battery Replacement, Battery: step 4, image 2 of 3 Asus MeMO Pad 7 (ME572C) Battery Replacement, Battery: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Disconnect the ZIF connectors to release the data cables holding the battery in. Use tweezers to do this.
    • You can also use your hand to remove ZIF connectors.
    • ZIF connectors are delicate so be careful when you are removing them.
  5. Asus MeMO Pad 7 (ME572C) Battery Replacement: step 5, image 1 of 1
    • Find the place where the battery connector is. Disconnect the battery connectors by carefully pulling up on them using a spudger or plastic opening tool.
  6. Asus MeMO Pad 7 (ME572C) Battery Replacement: step 6, image 1 of 3 Asus MeMO Pad 7 (ME572C) Battery Replacement: step 6, image 2 of 3 Asus MeMO Pad 7 (ME572C) Battery Replacement: step 6, image 3 of 3
    • Using a plastic opening tool carefully pry the battery loose. The battery is glued to the pad; slight pressure will be needed to remove the battery.
    • The casing of the battery is soft and can easily tear. Tearing can lead to the chemicals in the battery to leak out.
4 other people completed this guide.
Tyler Tripp
395 Reputation
2 Guides authored
USF Tampa, Team 14-23, Meier Fall 2015 Member of USF Tampa, Team 14-23, Meier Fall 2015
USFT-MEIER-F15S14G23
4 Members
14 Guides authored
One Comment
But whats the secret to cleaning off the glue and resealing it?
Pico Herbie - Reply
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 54
All Time: 35,932
