Asus MeMO Pad 7 ME170C Battery Replacement
  1. Asus MeMO Pad 7 ME170C  Battery Replacement, Battery: step 1, image 1 of 3 Asus MeMO Pad 7 ME170C  Battery Replacement, Battery: step 1, image 2 of 3 Asus MeMO Pad 7 ME170C  Battery Replacement, Battery: step 1, image 3 of 3
    • Before beginning to disassemble, Power off the device.
    • Excessive force can result in damaged or cracked screen. Be Gentle.
    • Gently wedge a Jimmy into the seam of the device.
    • Gently pry the Jimmy all around the seam until the back panel is detached.
  2. Asus MeMO Pad 7 ME170C  Battery Replacement: step 2, image 1 of 3 Asus MeMO Pad 7 ME170C  Battery Replacement: step 2, image 2 of 3 Asus MeMO Pad 7 ME170C  Battery Replacement: step 2, image 3 of 3
    • Locate the black bundle cable connector attached to the battery of the phone.
    • Do not push down. Slide in a forward motion to avoid breaking any inner pieces.
    • Using a plastic opening tool, gently slide the black bundle cable connector towards the battery in a back and forth motion until loosened and it slides out of connection port.
  3. Asus MeMO Pad 7 ME170C  Battery Replacement: step 3, image 1 of 3 Asus MeMO Pad 7 ME170C  Battery Replacement: step 3, image 2 of 3 Asus MeMO Pad 7 ME170C  Battery Replacement: step 3, image 3 of 3
    • Using a plastic opening tool, pry out the batteries to loosen them out.
    • The battery will be pried out of its port.
    • Lift the battery out of its port
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 3,150
