Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement
  1. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement, Motherboard: step 1, image 1 of 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement, Motherboard: step 1, image 2 of 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement, Motherboard: step 1, image 3 of 3
    • Power off the device before disassembly.
    • Be gentle; excessive force can result in a damaged or cracked screen.
    • Gently pry a Jimmy all around the seam of the device until the back panel detaches.
  2. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: step 2, image 1 of 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: step 2, image 2 of 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: step 2, image 3 of 3
    • Use an iFixit opening tool to gently push the black bundle cable connector in a forward motion until it loosens without pushing down on the bundle cable connector.
  3. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: step 3, image 1 of 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: step 3, image 2 of 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: step 3, image 3 of 3
    • Use the plastic opening tool to pry around the edges of the battery.
    • The battery should be laying freely in its port.
    • Lift the battery out of its port.
  4. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: step 4, image 1 of 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: step 4, image 2 of 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: step 4, image 3 of 3
    • Use a plastic opening tool to slide the white cable connector completely out of the port.
  5. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: step 5, image 1 of 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: step 5, image 2 of 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Flip up the beige clip to loosen the cable.
    • Use the wide nosed tweezers to pinch the blue tab attached to the ribbon cable.
    • Pull the blue tab gently in a lateral motion until it is completely out of its port.
  6. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: step 6, image 1 of 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: step 6, image 2 of 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: step 6, image 3 of 3
    • Use the wide nosed tweezers to gently pull out the orange ribbon inserted in the port on the motherboard.
  7. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: step 7, image 1 of 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: step 7, image 2 of 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: step 7, image 3 of 3
    • Use a plastic opening tool to push the white cable connector out of its port in a side to side motion.
  8. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: step 8, image 1 of 2 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: step 8, image 2 of 2
    • Use the Phillips #000 screwdriver to unscrew the seven screws.
    • There should be two silver and five black screws.
  9. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: step 9, image 1 of 2 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: step 9, image 2 of 2
    • Once the screws are removed, the speaker component will be loosely laying in the track.
    • Use the metal spudger tool to remove the speaker by gently lifting the edge of it.
  10. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: step 10, image 1 of 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: step 10, image 2 of 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: step 10, image 3 of 3
    • Remove the silver tape on one corner with the needle nosed tweezers, and remove the tape from the motherboard.
  11. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: step 11, image 1 of 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: step 11, image 2 of 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: step 11, image 3 of 3
    • Use the needle nosed tweezers to gently pull both of the orange ribbon cables out of their ports.
  12. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: step 12, image 1 of 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: step 12, image 2 of 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: step 12, image 3 of 3
    • Use the Phillips #000 screwdriver to unscrew all five screws.
  13. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: step 13, image 1 of 2 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: step 13, image 2 of 2
    • To uninstall the motherboard, use the metal spudger tool to lift it out of the device.
  14. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement, Rear Facing Camera: step 14, image 1 of 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement, Rear Facing Camera: step 14, image 2 of 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement, Rear Facing Camera: step 14, image 3 of 3
    Buy
    • Gently remove grey tape that is holding down connector for camera using the tweezers.
    • When tape is removed, use the plastic prying tool to gently unlock connector between camera wiring and motherboard. The connector lock rotates upward away from motherboard to release.
    • Carefully remove camera from motherboard using tweezers by pulling directly upward. Camera should release easily without much resistance.
Thomas Brooks
301 Reputation
3 Guides authored
IUPUI, Team S3-G3, Wilson Spring 2017 Member of IUPUI, Team S3-G3, Wilson Spring 2017
IUPUI-WILSON-S17S3G3
5 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 154
