Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement
  1. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement, LCD Screen Assembly: step 1, image 1 of 2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement, LCD Screen Assembly: step 1, image 2 of 2
    • Insert plastic opening tool in between screen and back cover to create initial separation between the two.
    • Then run plastic opening tool along end of screen to fully separate back cover from screen.
  2. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: step 2, image 1 of 2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: step 2, image 2 of 2
    • Remove screws (2.6mm) connecting speaker to hard frame with Phillips head screw driver (PH000).
  3. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Disconnect speaker wire from motherboard using metal pronged tweezers.
  4. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: step 4, image 1 of 1
    • Remove the screws (2.6mm) connecting the motherboard and battery tray to the hard frame with Phillip's head screw driver (PH000).
  5. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: step 5, image 1 of 2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: step 5, image 2 of 2
    • Remove the black bundle battery connector from the motherboard using plastic opening tools.
  6. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: step 6, image 1 of 2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: step 6, image 2 of 2
    • Use plastic opener tool to disconnect ZIF connectors as shown.
  7. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: step 7, image 1 of 3 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: step 7, image 2 of 3 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: step 7, image 3 of 3
    • Remove speaker housing to expose ZIF connection underneath.
    • Then using metal tweezers disconnect the ZIF connector.
  8. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: step 8, image 1 of 2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: step 8, image 2 of 2
    • Remove display and button connections from motherboard using metal tweezers.
  9. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: step 9, image 1 of 2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: step 9, image 2 of 2
    • Remove unscrewed battery tray from main frame.
  10. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: step 10, image 1 of 2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: step 10, image 2 of 2
    • Remove motherboard from hard frame.
    • When removing the motherboard make sure all screws that attach motherboard to hardframe are removed and to release plastic tab as shown in image.
  11. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: step 11, image 1 of 2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: step 11, image 2 of 2
    • Peel off button sensors off the side of the hard frame.
  12. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: step 12, image 1 of 3 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: step 12, image 2 of 3 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: step 12, image 3 of 3
    • Apply slight pressure on camera to break adhesive to finish screen disassembly processes.
Nejad Harara
110 Reputation
1 Guide authored
Cal Poly, Team S6-G3, Banghart Fall 2017 Member of Cal Poly, Team S6-G3, Banghart Fall 2017
CPSU-BANGHART-F17S6G3
5 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 1,725
