Introduction
This guide will take you through the necessary steps to replace the speakers in your Asus MeMO Pad 7 ME176C.
Make sure the device is turned off.
Carefully insert the opening tool on the edge of the phone.
Slowly lift up the panel from the device and repeat the process on the other side.
To disconnect the ZIF connectors. Place the metal spudger underneath the ZIF cable and gently pull it outward.
Using a Philips Head Screwdriver PH000, locate the 2.6mm screws and gently unscrew them .
