Asus MeMO Pad 8 ME181C Rear Facing Camera Replacement
  1. Asus MeMO Pad 8 ME181C Rear Facing Camera Replacement, Rear Case: step 1, image 1 of 2 Asus MeMO Pad 8 ME181C Rear Facing Camera Replacement, Rear Case: step 1, image 2 of 2
    • Insert a plastic opening tool into the seam between the rear case and the screen.
    • Work the plastic opening tool around the perimeter of the device to completely remove the rear case.
  2. Asus MeMO Pad 8 ME181C Rear Facing Camera Replacement, Motherboard: step 2, image 1 of 1
    • Working from top to bottom, you will remove all screws with a #000 Phillips head driver, (20) total.
    • (2) screws located in the top corners. NOTE: These screws will be in the speakers.
    • (4) screws located along the top of the battery, (3) along each side of the battery, and (3) along the bottom of the battery.
    • (1) screw in the middle of the motherboard on the side with the orange ribbon cable, (4) screws in the bottom of the motherboard .
  3. Asus MeMO Pad 8 ME181C Rear Facing Camera Replacement: step 3, image 1 of 1
    • Make sure that the battery is disconnected from the motherboard by unplugging the ribbon cables.
  4. Asus MeMO Pad 8 ME181C Rear Facing Camera Replacement: step 4, image 1 of 2 Asus MeMO Pad 8 ME181C Rear Facing Camera Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Before you remove the entire assembly, first unplug side buttons and cameras from the motherboard using tweezers.
    • The motherboard is easiest to remove simultaneously with the battery. Refer to Step 5 for more details.
  5. Asus MeMO Pad 8 ME181C Rear Facing Camera Replacement: step 5, image 1 of 2 Asus MeMO Pad 8 ME181C Rear Facing Camera Replacement: step 5, image 2 of 2
    • While the device is open, this is your opportunity to check and see if there is any other damage to the motherboard or other associated parts.
  6. Asus MeMO Pad 8 ME181C Rear Facing Camera Replacement, Rear Facing Camera: step 6, image 1 of 1
    • Now carefully pry up the rear facing camera using a spudger.
    • Be careful when using the spudger as you do not want the tool to slip and damage other components of the tablet.
Anthony Tillett
214 Reputation
2 Guides authored
USF Tampa, Team 5-6, Lacy Fall 2016 Member of USF Tampa, Team 5-6, Lacy Fall 2016
USFT-LACY-F16S5G6
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 239
