Asus Memo Pad ME172V - Touch Screen Replacement
Video Overview
  1. Asus Memo Pad ME172V - Touch Screen Replacement, Touch Screen replacement: step 1, image 1 of 3 Asus Memo Pad ME172V - Touch Screen Replacement, Touch Screen replacement: step 1, image 2 of 3 Asus Memo Pad ME172V - Touch Screen Replacement, Touch Screen replacement: step 1, image 3 of 3
    • Switch-off the tablet.
    • By using a plastic tool open the back / battery cover.
  2. Asus Memo Pad ME172V - Touch Screen Replacement: step 2, image 1 of 3 Asus Memo Pad ME172V - Touch Screen Replacement: step 2, image 2 of 3 Asus Memo Pad ME172V - Touch Screen Replacement: step 2, image 3 of 3
    • Disconnect and remove the battery.
  3. Asus Memo Pad ME172V - Touch Screen Replacement: step 3, image 1 of 3 Asus Memo Pad ME172V - Touch Screen Replacement: step 3, image 2 of 3 Asus Memo Pad ME172V - Touch Screen Replacement: step 3, image 3 of 3
    • Disconnect the LCD display flex cable.
    • Disconnect the touchscreen flex cable.
    • Disconnect and remove the loudspeaker.
    • Unscrew 10x screws.
    • Now you can remove the mother board
  4. Asus Memo Pad ME172V - Touch Screen Replacement: step 4, image 1 of 3 Asus Memo Pad ME172V - Touch Screen Replacement: step 4, image 2 of 3 Asus Memo Pad ME172V - Touch Screen Replacement: step 4, image 3 of 3
    • Remove the metal LCD display shield.
  5. Asus Memo Pad ME172V - Touch Screen Replacement, Separate the LCD panel from the digitizer: step 5, image 1 of 3 Asus Memo Pad ME172V - Touch Screen Replacement, Separate the LCD panel from the digitizer: step 5, image 2 of 3 Asus Memo Pad ME172V - Touch Screen Replacement, Separate the LCD panel from the digitizer: step 5, image 3 of 3
    • There are many clips holding the LCD panel to the metal frame.
    • Use a spudger to loosen the clips holding the LCD display.
  6. Asus Memo Pad ME172V - Touch Screen Replacement: step 6, image 1 of 3 Asus Memo Pad ME172V - Touch Screen Replacement: step 6, image 2 of 3 Asus Memo Pad ME172V - Touch Screen Replacement: step 6, image 3 of 3
    • Heat the touch screen.
    • Use a cutter only to start detachment the touchscreen. Then continue with a plastic tool.
  7. Asus Memo Pad ME172V - Touch Screen Replacement: step 7, image 1 of 3 Asus Memo Pad ME172V - Touch Screen Replacement: step 7, image 2 of 3 Asus Memo Pad ME172V - Touch Screen Replacement: step 7, image 3 of 3
    • After separation the touchscreen from the front bezel, remove the LCD display frame.
    • This spare part have a double sided adhesive tape. Otherwise you should place.
    • Did you do it successfully?
    • Please SUBSCRIBE to my channel ツ
8 other people completed this guide.
ZFix
191,882 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,516 Guides authored
One Comment
Is it possible to replace the bezel the way you would an iPad screen instead of going from the back? I feel like a head gun to the front would save you a lot of hassle? Please correct me if I'm wrong
Alex Tucker - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 23,511
