Introduction
This guide will show you how to remove the side buttons of your Asus PadFone S. Some common tools are required for this replacement so make sure you have them before you start. This guide will make it easy to replace a broken side buttons to get your phone working again.
Remove all screws using a T5 Torx screwdriver.
After removing screws, lift the back panel off of the phone.
Turn the phone so the left edge is facing you.
Using your fingers, gently pull up on the buttons to remove them from the phone.
