Asus Padfone 2 Battery Replacement
  1. Asus Padfone 2 Battery Replacement, Power off phone: step 1, image 1 of 1
    • Hold down power button to shut off phone.
  2. Asus Padfone 2 Battery Replacement, Remove back cover of phone: step 2, image 1 of 2 Asus Padfone 2 Battery Replacement, Remove back cover of phone: step 2, image 2 of 2
    • Use plastic opening tool to pry off the back cover of the phone.
  3. Asus Padfone 2 Battery Replacement, Battery Removal: step 3, image 1 of 3 Asus Padfone 2 Battery Replacement, Battery Removal: step 3, image 2 of 3 Asus Padfone 2 Battery Replacement, Battery Removal: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the warning sticker that covers the battery plug and connecting cord.
    • Look for the widest gap on either side of the battery. Using the plastic opening tool carefully lift battery out.
    • The battery is held down with adhesive. Be careful not to damage battery or connecting cord
    • Disconnect battery connecting cord using tweezers.
6 other people completed this guide.
Zach Standridge
350 Reputation
2 Guides authored
USF Tampa, Team 5-4, Mcgee Fall 2014 Member of USF Tampa, Team 5-4, Mcgee Fall 2014
USFT-MCGEE-F14S5G4
4 Members
7 Guides authored
One Comment
Pull the battery connector towards USB. You will break it if you pull it up, as I did.
I wouldn’t recommend metal tweezers as it could shortcut the battery.
Los Karlos - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 14
All Time: 5,958
