Asus Padfone X Mini Camera Replacement
  1. Asus Padfone X Mini Camera Replacement, Speaker: step 1, image 1 of 1
    • With the phone facing down, look at the bottom right side corner and there should be a groove. Use a plastic opening tool and lift up to remove outside cover.
    • This is not the cover with the speaker attached.
  2. Asus Padfone X Mini Camera Replacement: step 2, image 1 of 1
    • Lift the battery out from the top of the device.
  3. Asus Padfone X Mini Camera Replacement: step 3, image 1 of 1
    • Around the perimeter, there should be 10 2 mm T5 Torx screws. Take them out.
    • Remove the cover.
  4. Asus Padfone X Mini Camera Replacement: step 4, image 1 of 1
    • Turn the cover over.
    • The speaker is attached to the inside of the cover and to the right of the camera hole.
  5. Asus Padfone X Mini Camera Replacement: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Remove speaker with standard tweezers to minimize damage, and replace.
  6. Asus Padfone X Mini Camera Replacement, Screen: step 6, image 1 of 1
    • Detach the black connector on the left hand side of the motherboard.
    • Don't completely remove the black connector.
  7. Asus Padfone X Mini Camera Replacement: step 7, image 1 of 1
    • Disconnect silver connector from the motherboard. It is located on the left hand side above the black connector.
  8. Asus Padfone X Mini Camera Replacement: step 8, image 1 of 2 Asus Padfone X Mini Camera Replacement: step 8, image 2 of 2
    • Remove motherboard and replace screen.
  9. Asus Padfone X Mini Camera Replacement, Camera: step 9, image 1 of 1
    • Turn over the motherboard.
  10. Asus Padfone X Mini Camera Replacement: step 10, image 1 of 1
    Buy
    • Using tweezers pull out the connector that connects the camera to the motherboard.
  11. Asus Padfone X Mini Camera Replacement: step 11, image 1 of 2 Asus Padfone X Mini Camera Replacement: step 11, image 2 of 2
    • Take out the camera.
    • Put in the new camera by sliding the camera connector into the receiver.
James Jackson
97 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 192
