Asus Q200E-CT144H Screen Replacement
  1. Asus Q200E-CT144H Screen Replacement, Screen: step 1, image 1 of 1
    • Turn off the laptop and disconnect the power cable.
    • If the laptop is powered on, it could cause an electric shock.
    • Open the laptop and place it on a hard, flat surface with the screen facing up.
  2. Asus Q200E-CT144H Screen Replacement: step 2, image 1 of 2 Asus Q200E-CT144H Screen Replacement: step 2, image 2 of 2
    • Take a metal spudger and insert it under the screen.
    • Slowly move the spudger across the length of the screen, separating the sections.
  3. Asus Q200E-CT144H Screen Replacement: step 3, image 1 of 1
    • Remove the four 3.3mm Phillips #00 screws.
  4. Asus Q200E-CT144H Screen Replacement: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Pull apart the screen from the casing of the laptop.
    • Disconnect the power connector using tweezers.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 295
