Asus Q302UA-BHI5T20 Fan and Heat Sink Replacement
  1. Asus Q302UA-BHI5T20 Fan and Heat Sink Replacement, Fan and Heat Sink: step 1, image 1 of 2 Asus Q302UA-BHI5T20 Fan and Heat Sink Replacement, Fan and Heat Sink: step 1, image 2 of 2
    • Unscrew the ten 10mm Phillips #0 screws.
    • Use the plastic opening tool along the side of the laptop to pry open.
  2. Asus Q302UA-BHI5T20 Fan and Heat Sink Replacement: step 2, image 1 of 2 Asus Q302UA-BHI5T20 Fan and Heat Sink Replacement: step 2, image 2 of 2
    • Remove the seven 4mm Phillips #0 screws.
    • Gently pull the connector.
  3. Asus Q302UA-BHI5T20 Fan and Heat Sink Replacement: step 3, image 1 of 1
    • Lift the heat sink and fan assembly, and you are done!
    • There maybe a little resistance to being pulled up since the heat sink is attached to the CPU with thermal paste
Arthur Sperotto
118 Reputation
1 Guide authored
IUPUI, Team S1-G2, Hovde Fall 2018 Member of IUPUI, Team S1-G2, Hovde Fall 2018
IUPUI-HOVDE-F18S1G2
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 136
