Asus Q302UA-BHI5T20 Hard Drive Replacement
  1. Asus Q302UA-BHI5T20 Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
    • Remove the ten 10mm Phillips #0 screws.
  2. Asus Q302UA-BHI5T20 Hard Drive Replacement: step 2, image 1 of 1
    • Use the iFixit opening tool to pry off the back cover of the laptop.
  3. Asus Q302UA-BHI5T20 Hard Drive Replacement: step 3, image 1 of 2 Asus Q302UA-BHI5T20 Hard Drive Replacement: step 3, image 2 of 2
    • Remove the four screws from the hard drive bracket.
    • Remove the five 4 mm Phillips screws.
  4. Asus Q302UA-BHI5T20 Hard Drive Replacement: step 4, image 1 of 2 Asus Q302UA-BHI5T20 Hard Drive Replacement: step 4, image 2 of 2
    • Pull on this black connector piece to remove it from the hard drive.
    • The second picture shows how things should look at this point.
  5. Asus Q302UA-BHI5T20 Hard Drive Replacement: step 5, image 1 of 1
    • Remove these two 4 mm Phillips screws holding the hard drive to the bracket. Repeat on the other side of the bracket.
    • Pull the HD from its housing.
3 other people completed this guide.
Houston Koontz
319 Reputation
2 Guides authored
IUPUI, Team S1-G2, Hovde Fall 2018 Member of IUPUI, Team S1-G2, Hovde Fall 2018
IUPUI-HOVDE-F18S1G2
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 382
