Asus Q325U CPU Fan Replacement
  1. Asus Q325U CPU Fan Replacement, Back Panel: step 1, image 1 of 3 Asus Q325U CPU Fan Replacement, Back Panel: step 1, image 2 of 3 Asus Q325U CPU Fan Replacement, Back Panel: step 1, image 3 of 3
    • Remove the ten 5mm screws using a T5 Torx screwdriver.
  2. Asus Q325U CPU Fan Replacement: step 2, image 1 of 3 Asus Q325U CPU Fan Replacement: step 2, image 2 of 3 Asus Q325U CPU Fan Replacement: step 2, image 3 of 3
    • Lift the back panel upward using the suction tool.
  3. Asus Q325U CPU Fan Replacement, Copper Plate: step 3, image 1 of 2 Asus Q325U CPU Fan Replacement, Copper Plate: step 3, image 2 of 2
    • Remove the six 3mm screws using a Phillips #00.
  4. Asus Q325U CPU Fan Replacement: step 4, image 1 of 2 Asus Q325U CPU Fan Replacement: step 4, image 2 of 2
    • Use the plastic opening tool to lift up the edge. Pull upward on the edge.
  5. Asus Q325U CPU Fan Replacement: step 5, image 1 of 2 Asus Q325U CPU Fan Replacement: step 5, image 2 of 2
    • On the other side of the plate, remove the tape.
  6. Asus Q325U CPU Fan Replacement, CPU Fan: step 6, image 1 of 2 Asus Q325U CPU Fan Replacement, CPU Fan: step 6, image 2 of 2
    • Remove the three 3.7 mm screws using a Phillips #00 screwdriver.
  7. Asus Q325U CPU Fan Replacement: step 7, image 1 of 1
    • Detach the black wire and plug shown using a tweezer.
  8. Asus Q325U CPU Fan Replacement: step 8, image 1 of 1
    • Grab CPU fan by its edge and gently pull upwards to remove.
2 other people completed this guide.
Matthew Slawson
271 Reputation
2 Guides authored
Cal Poly, Team S19-G1, White Winter 2019 Member of Cal Poly, Team S19-G1, White Winter 2019
CPSU-WHITE-W19S19G1
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 814
