Asus Q325U Keyboard Replacement
  1. Asus Q325U Keyboard Replacement, Back Panel: step 1, image 1 of 3 Asus Q325U Keyboard Replacement, Back Panel: step 1, image 2 of 3 Asus Q325U Keyboard Replacement, Back Panel: step 1, image 3 of 3
    • Remove the ten 5mm screws using a T5 Torx screwdriver.
  2. Asus Q325U Keyboard Replacement: step 2, image 1 of 3 Asus Q325U Keyboard Replacement: step 2, image 2 of 3 Asus Q325U Keyboard Replacement: step 2, image 3 of 3
    • Lift the back panel upward using the suction tool.
  3. Asus Q325U Keyboard Replacement, SSD: step 3, image 1 of 2 Asus Q325U Keyboard Replacement, SSD: step 3, image 2 of 2
    • Remove one 2mm screw on top of the SSD using a Phillips #1 screwdriver.
  4. Asus Q325U Keyboard Replacement: step 4, image 1 of 2 Asus Q325U Keyboard Replacement: step 4, image 2 of 2
    • Carefully slide and lift the SSD to remove it.
  5. Asus Q325U Keyboard Replacement, Battery: step 5, image 1 of 2 Asus Q325U Keyboard Replacement, Battery: step 5, image 2 of 2
    • Remove the seven 5mm screws around the battery using a Phillips #00 screwdriver.
  6. Asus Q325U Keyboard Replacement: step 6, image 1 of 2 Asus Q325U Keyboard Replacement: step 6, image 2 of 2
    • Using a Phillips #000 screwdriver, remove the two 3mm screws on top of the orange battery connector.
  7. Asus Q325U Keyboard Replacement: step 7, image 1 of 2 Asus Q325U Keyboard Replacement: step 7, image 2 of 2
    • Lift the battery out from the laptop.
  8. Asus Q325U Keyboard Replacement, Copper Plate: step 8, image 1 of 2 Asus Q325U Keyboard Replacement, Copper Plate: step 8, image 2 of 2
    • Remove the six 3mm screws using a Phillips #00.
  9. Asus Q325U Keyboard Replacement: step 9, image 1 of 2 Asus Q325U Keyboard Replacement: step 9, image 2 of 2
    • Use the plastic opening tool to lift up the edge. Pull upward on the edge.
  10. Asus Q325U Keyboard Replacement: step 10, image 1 of 2 Asus Q325U Keyboard Replacement: step 10, image 2 of 2
    • On the other side of the plate, remove the tape.
  11. Asus Q325U Keyboard Replacement, CPU Fan: step 11, image 1 of 2 Asus Q325U Keyboard Replacement, CPU Fan: step 11, image 2 of 2
    • Remove the three 3.7 mm screws using a Phillips #00 screwdriver.
  12. Asus Q325U Keyboard Replacement: step 12, image 1 of 1
    • Detach the black wire and plug shown using a tweezer.
  13. Asus Q325U Keyboard Replacement: step 13, image 1 of 1
    • Grab CPU fan by its edge and gently pull upwards to remove.
  14. Asus Q325U Keyboard Replacement, Motherboard: step 14, image 1 of 2 Asus Q325U Keyboard Replacement, Motherboard: step 14, image 2 of 2
    Tool used on this step:
    Halberd Spudger
    $2.99
    Buy
    • Remove the first connection wire by pulling the small back loop with the Halberd Spudger.
  15. Asus Q325U Keyboard Replacement: step 15, image 1 of 3 Asus Q325U Keyboard Replacement: step 15, image 2 of 3 Asus Q325U Keyboard Replacement: step 15, image 3 of 3
    Buy
    • Lift the small black tab of the orange connector with your fingers or a plastic opening tool.
    • Remove the orange connector by pulling with tweezers.
  16. Asus Q325U Keyboard Replacement: step 16, image 1 of 3 Asus Q325U Keyboard Replacement: step 16, image 2 of 3 Asus Q325U Keyboard Replacement: step 16, image 3 of 3
    • Lift the small black tab on the white plastic piece of the touch pad connector with a spudger.
    • Remove the touch pad connector by pulling with tweezers.
  17. Asus Q325U Keyboard Replacement: step 17, image 1 of 3 Asus Q325U Keyboard Replacement: step 17, image 2 of 3 Asus Q325U Keyboard Replacement: step 17, image 3 of 3
    • Lift the black tab on the long white plastic piece of the thick blue band.
    • Remove the thick blue band by pulling.
  18. Asus Q325U Keyboard Replacement: step 18, image 1 of 3 Asus Q325U Keyboard Replacement: step 18, image 2 of 3 Asus Q325U Keyboard Replacement: step 18, image 3 of 3
    • Remove the two Phillips #000 screws on the metal connector above the thick orange band.
    • Lift up the thick orange band.
  19. Asus Q325U Keyboard Replacement: step 19, image 1 of 3 Asus Q325U Keyboard Replacement: step 19, image 2 of 3 Asus Q325U Keyboard Replacement: step 19, image 3 of 3
    • Gently lift up the two smallest connectors using your fingers or a plastic opening tool.
  20. Asus Q325U Keyboard Replacement: step 20, image 1 of 2 Asus Q325U Keyboard Replacement: step 20, image 2 of 2
    • Lift up the black hinge of the connector using a plastic opening tool.
    • Remove the connector using a tweezer.
  21. Asus Q325U Keyboard Replacement: step 21, image 1 of 3 Asus Q325U Keyboard Replacement: step 21, image 2 of 3 Asus Q325U Keyboard Replacement: step 21, image 3 of 3
    • Pull up the tap of the biggest connector using your fingers.
    • Lift the gold hinge using a plastic opening tool.
    • Lift the connector up with your fingers to remove.
  22. Asus Q325U Keyboard Replacement: step 22, image 1 of 2 Asus Q325U Keyboard Replacement: step 22, image 2 of 2
    • Remove the four 4.8 mm screws using a Phillips #00 screwdriver.
  23. Asus Q325U Keyboard Replacement: step 23, image 1 of 2 Asus Q325U Keyboard Replacement: step 23, image 2 of 2
    • Slightly open up the laptop. This will lift up the hinge at the corner and free the motherboard.
  24. Asus Q325U Keyboard Replacement: step 24, image 1 of 2 Asus Q325U Keyboard Replacement: step 24, image 2 of 2
    • Pull the motherboard away from the corner to remove.
  25. Asus Q325U Keyboard Replacement, Keyboard: step 25, image 1 of 3 Asus Q325U Keyboard Replacement, Keyboard: step 25, image 2 of 3 Asus Q325U Keyboard Replacement, Keyboard: step 25, image 3 of 3
    • Remove the three 4 mm screws using a Phillips #00 screwdriver.
    • Remove the four 4.8 mm screws using a Phillips #000 screwdriver.
  26. Asus Q325U Keyboard Replacement: step 26, image 1 of 1
    • Slide out the blue chip board connected to the long orange piece by gently grabbing the tab and lifting.
  27. Asus Q325U Keyboard Replacement: step 27, image 1 of 1
    • Release the single MB wire by removing the black piece of tape.
  28. Asus Q325U Keyboard Replacement: step 28, image 1 of 1
    • Untape the blue striped strip by pulling upwards and laying it flat.
  29. Asus Q325U Keyboard Replacement: step 29, image 1 of 3 Asus Q325U Keyboard Replacement: step 29, image 2 of 3 Asus Q325U Keyboard Replacement: step 29, image 3 of 3
    • Starting at the upper left corner, remove the black adhesive from the keyboard.
  30. Asus Q325U Keyboard Replacement: step 30, image 1 of 2 Asus Q325U Keyboard Replacement: step 30, image 2 of 2
    • Remove eighty 1 mm screws located on the keyboard frame using a Phillips #000 screwdriver.
  31. Asus Q325U Keyboard Replacement: step 31, image 1 of 1
    • Grab the edge of the keyboard and lift upwards to remove.
Matthew Slawson
271 Reputation
2 Guides authored
Cal Poly, Team S19-G1, White Winter 2019 Member of Cal Poly, Team S19-G1, White Winter 2019
CPSU-WHITE-W19S19G1
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 734
