Asus Q325U SSD Replacement
  1. Asus Q325U SSD Replacement, Back Panel: step 1, image 1 of 3 Asus Q325U SSD Replacement, Back Panel: step 1, image 2 of 3 Asus Q325U SSD Replacement, Back Panel: step 1, image 3 of 3
    • Remove the ten 5mm screws using a T5 Torx screwdriver.
  2. Asus Q325U SSD Replacement: step 2, image 1 of 3 Asus Q325U SSD Replacement: step 2, image 2 of 3 Asus Q325U SSD Replacement: step 2, image 3 of 3
    • Lift the back panel upward using the suction tool.
  3. Asus Q325U SSD Replacement, SSD: step 3, image 1 of 2 Asus Q325U SSD Replacement, SSD: step 3, image 2 of 2
    • Remove one 2mm screw on top of the SSD using a Phillips #1 screwdriver.
  4. Asus Q325U SSD Replacement: step 4, image 1 of 2 Asus Q325U SSD Replacement: step 4, image 2 of 2
    • Carefully slide and lift the SSD to remove it.
2 other people completed this guide.
Jacob Tang
401 Reputation
3 Guides authored
Cal Poly, Team S19-G1, White Winter 2019 Member of Cal Poly, Team S19-G1, White Winter 2019
CPSU-WHITE-W19S19G1
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 16
All Time: 1,045
