Asus Q500A Battery Replacement
  1. Asus Q500A Battery Replacement, Battery: step 1, image 1 of 1
    • Flip device onto backside.
  2. Asus Q500A Battery Replacement: step 2, image 1 of 1
    • Locate the two sliding locks.
    • Slide the sliding lock 1 to the right to unlock it .
    • There should be a red marker to indicate that it is unlocked. This lock will stay unlocked until slid back into the locked position.
  3. Asus Q500A Battery Replacement: step 3, image 1 of 1
    • Slide the sliding lock 2 to the left to unlock it.
    • There will not be any indicator that it is unlocked. This lock will relock if you do not continue to push it to the left.
  4. Asus Q500A Battery Replacement: step 4, image 1 of 1
    • While the first and second lock are unlocked, slide the battery out to remove it.
    • When reinserting the replacement battery, make sure to slide sliding lock 1 back into the locked position. Otherwise the battery may come loose.
cameron
319 Reputation
3 Guides authored
USF Tampa, Team 12-5, Eyestone Spring 2017 Member of USF Tampa, Team 12-5, Eyestone Spring 2017
USFT-EYESTONE-S17S12G5
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 497
