Asus Q500A Hard Drive Replacement
  1. Asus Q500A Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
    • Flip device onto backside
  2. Asus Q500A Hard Drive Replacement: step 2, image 1 of 1
    • Use a J0 screwdriver bit to remove both screws on the back-plate, found at the bottom of device.
    • Remove back-plate.
    • Note: Use prying tool if your having issues lifting back-plate.
  3. Asus Q500A Hard Drive Replacement: step 3, image 1 of 2 Asus Q500A Hard Drive Replacement: step 3, image 2 of 2
    • Remove 4 screws from the metal hard-drive case. There will be one in each corner.
    • Remove the hard-drive case from the device.
  4. Asus Q500A Hard Drive Replacement: step 4, image 1 of 1
    • Remove the hard-drive. It will be connected to the integrated sata-port in the device.
    • Place hard-drive into slot and connect to the integrated sata port.
    • Place hard drive case back on top of the new hard-drive.
    • Screw in the four screws on the hard-drive case.
  5. Asus Q500A Hard Drive Replacement: step 6, image 1 of 1
    • Place back-plate back on device.
    • Screw in the 2 screws on the back of the plate.
2 other people completed this guide.
cameron
319 Reputation
3 Guides authored
USF Tampa, Team 12-5, Eyestone Spring 2017 Member of USF Tampa, Team 12-5, Eyestone Spring 2017
USFT-EYESTONE-S17S12G5
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 991
