Asus Q501LA-BBI6T03 Battery Replacement
  1. Asus Q501LA-BBI6T03 Battery Replacement, Back Panel: step 1, image 1 of 1
    • Ensure the laptop is powered down before continuing.
    • Use a Phillips #0 screwdriver to remove the ten 3mm Phillips head screws on the base of the laptop.
  2. Asus Q501LA-BBI6T03 Battery Replacement: step 2, image 1 of 1
    • Use the spudger to pry open the rear cover at either hinge.
  3. Asus Q501LA-BBI6T03 Battery Replacement: step 3, image 1 of 2 Asus Q501LA-BBI6T03 Battery Replacement: step 3, image 2 of 2
    • Grab the cover with your fingers and gently lift it away from the board.
    • Be careful not to break any tabs on the cover when lifting it off.
  4. Asus Q501LA-BBI6T03 Battery Replacement, Battery: step 4, image 1 of 1
    • Remove the five silver 4mm Phillips #0 screws holding the battery to the laptop.
  5. Asus Q501LA-BBI6T03 Battery Replacement: step 5, image 1 of 1
    • Using the spudger, carefully remove the power cable connecting the battery to the rest of the laptop.
  6. Asus Q501LA-BBI6T03 Battery Replacement: step 6, image 1 of 1
    • Once the screws and cable are removed, carefully lift the battery from the laptop.
7 other people completed this guide.
Kyle Nagao
366 Reputation
2 Guides authored
Cal Poly, Team 8-1, Banghart Winter 2017 Member of Cal Poly, Team 8-1, Banghart Winter 2017
CPSU-BANGHART-W17S8G1
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 24
All Time: 5,604
