Asus Q501LA-BBI6T03 RAM Replacement
  1. Asus Q501LA-BBI6T03 RAM Replacement, Back Panel: step 1, image 1 of 1
    • Ensure the laptop is powered down before continuing.
    • Use a Phillips #0 screwdriver to remove the ten 3mm Phillips head screws on the base of the laptop.
  2. Asus Q501LA-BBI6T03 RAM Replacement: step 2, image 1 of 1
    • Use the spudger to pry open the rear cover at either hinge.
  3. Asus Q501LA-BBI6T03 RAM Replacement: step 3, image 1 of 2 Asus Q501LA-BBI6T03 RAM Replacement: step 3, image 2 of 2
    • Grab the cover with your fingers and gently lift it away from the board.
    • Be careful not to break any tabs on the cover when lifting it off.
  4. Asus Q501LA-BBI6T03 RAM Replacement, RAM: step 4, image 1 of 2 Asus Q501LA-BBI6T03 RAM Replacement, RAM: step 4, image 2 of 2
    • Press down the metal tabs on both sides of the RAM.
    • The tabs are spring loaded and the RAM will pop up immediately.
3 other people completed this guide.
Tanner
276 Reputation
2 Guides authored
Cal Poly, Team 8-1, Banghart Winter 2017 Member of Cal Poly, Team 8-1, Banghart Winter 2017
CPSU-BANGHART-W17S8G1
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 602
