Asus Q502LA-BSI5T14 Fan Replacement
  1. Asus Q502LA-BSI5T14 Fan Replacement, Fan: step 1, image 1 of 1
    • Make sure your device is powered off before you begin.
    • Flip the laptop over and remove the ten 11 mm Phillips #1 screws securing the back panel.
  2. Asus Q502LA-BSI5T14 Fan Replacement: step 2, image 1 of 1
    • Carefully insert a plastic opening tool under one corner of the back panel.
    • Slide the tool along the seam to gently pry the panel up and away from the device.
  3. Asus Q502LA-BSI5T14 Fan Replacement: step 3, image 1 of 1
    • Remove the eight 5 mm Phillips #1 screws securing the fan and copper piece to the motherboard.
    • Remove the wires by gently pulling them out.
  4. Asus Q502LA-BSI5T14 Fan Replacement: step 4, image 1 of 1
    • Gently lift the fan up and away from the laptop.
Mary Kounelas
715 Reputation
5 Guides authored
USF Tampa, Team S4-G1, Eyestone Fall 2017 Member of USF Tampa, Team S4-G1, Eyestone Fall 2017
USFT-EYESTONE-F17S4G1
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 392
