Asus Q502LA-BSI5T14 Motherboard Replacement
  1. Asus Q502LA-BSI5T14 Motherboard Replacement, Battery: step 1, image 1 of 1
    • Ensure your device is powered off before starting.
    • Flip the laptop over and remove the ten 10 mm Phillips #1 screws securing the back panel.
  2. Asus Q502LA-BSI5T14 Motherboard Replacement: step 2, image 1 of 1
    • Carefully insert a plastic opening tool under one corner of the back panel.
    • Slide the tool along the seam to gently pry the panel up and away from the device.
  3. Asus Q502LA-BSI5T14 Motherboard Replacement: step 3, image 1 of 2 Asus Q502LA-BSI5T14 Motherboard Replacement: step 3, image 2 of 2
    • The battery is the large L-shaped block.
    • Remove the five 5.5 mm Phillips #1 screws securing it.
  4. Asus Q502LA-BSI5T14 Motherboard Replacement: step 4, image 1 of 2 Asus Q502LA-BSI5T14 Motherboard Replacement: step 4, image 2 of 2
    • Using a plastic opening tool, lift the battery straight upward to remove it.
    • There are a series of eight small wires connecting the battery to the motherboard. Make sure you gently lift the battery straight up to disconnect these wires and prevent damage.
  5. Asus Q502LA-BSI5T14 Motherboard Replacement, Motherboard: step 5, image 1 of 2 Asus Q502LA-BSI5T14 Motherboard Replacement, Motherboard: step 5, image 2 of 2
    • Remove the four ribbons connected to the motherboard.
  6. Asus Q502LA-BSI5T14 Motherboard Replacement: step 6, image 1 of 2 Asus Q502LA-BSI5T14 Motherboard Replacement: step 6, image 2 of 2
    • Disconnect the five wires attached to the motherboard by pulling gently. There are three thin wires in the upper left corner.
  7. Asus Q502LA-BSI5T14 Motherboard Replacement: step 7, image 1 of 1
    • Remove the two 5 mm Phillips #1 screws attaching the stabilizer to the motherboard
  8. Asus Q502LA-BSI5T14 Motherboard Replacement: step 8, image 1 of 1
    • Remove the four 5 mm Phillips #1 screws around the perimeter of the motherboard.
  9. Asus Q502LA-BSI5T14 Motherboard Replacement: step 9, image 1 of 2 Asus Q502LA-BSI5T14 Motherboard Replacement: step 9, image 2 of 2
    • Remove the six 5 mm Phillips #1 screws securing the silver plates to the motherboard.
    • Open the laptop approximately 1/2" to loosen the hinge and release the motherboard.
  10. Asus Q502LA-BSI5T14 Motherboard Replacement: step 10, image 1 of 1
    • Gently lift the motherboard out and away from the laptop.
3 other people completed this guide.
Mary Kounelas
715 Reputation
5 Guides authored
USF Tampa, Team S4-G1, Eyestone Fall 2017 Member of USF Tampa, Team S4-G1, Eyestone Fall 2017
USFT-EYESTONE-F17S4G1
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 25
All Time: 1,628
