Asus Q502LA-BSI5T14 RAM Replacement
  1. Asus Q502LA-BSI5T14 RAM Replacement, RAM: step 1, image 1 of 1
    • Ensure your device is powered off before starting
    • Flip the laptop so the back panel is facing up.
    • Remove the ten 10 mm Phillips #1 screws securing the back panel.
  2. Asus Q502LA-BSI5T14 RAM Replacement: step 2, image 1 of 1
    • Carefully insert a plastic opening tool under one corner of the back panel.
    • Slide the tool along the seam to gently pry the panel up and away from the device.
  3. Asus Q502LA-BSI5T14 RAM Replacement: step 3, image 1 of 3 Asus Q502LA-BSI5T14 RAM Replacement: step 3, image 2 of 3 Asus Q502LA-BSI5T14 RAM Replacement: step 3, image 3 of 3
    • The RAM is the rectangular plate in the center.
    • Use a spudger to press the clips securing the RAM outward. The RAM will pop up enabling you to lift it out.
Mary Kounelas
715 Reputation
5 Guides authored
USF Tampa, Team S4-G1, Eyestone Fall 2017 Member of USF Tampa, Team S4-G1, Eyestone Fall 2017
USFT-EYESTONE-F17S4G1
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 22
All Time: 580
