Asus Q503UA Battery Replacement
  1. Asus Q503UA Battery Replacement, Battery Replacement: step 1, image 1 of 1
    • Flip the computer upside down. In order to ensure that the correct side is up, you should be able to read the sticker that indicates the serial number on the bottom.
  2. Asus Q503UA Battery Replacement: step 2, image 1 of 2 Asus Q503UA Battery Replacement: step 2, image 2 of 2
    • Remove the ten circled screws along the perimeter of the laptop with a Phillips #0 screwdriver.
  3. Asus Q503UA Battery Replacement: step 3, image 1 of 3 Asus Q503UA Battery Replacement: step 3, image 2 of 3 Asus Q503UA Battery Replacement: step 3, image 3 of 3
    • Starting from the top right corner, use a plastic prying tool to separate the cover from the laptop. Use light pressure to prevent the plastic from breaking.
    • You should feel the frame coming loose. If necessary, use spacers to keep the frame from locking back into place.
    • Repeat the above step around the laptop until you are able to lift the cover.
To reinstall the back cover, follow these instructions in reverse order.
5 other people completed this guide.
Gilberto Coronado
145 Reputation
1 Guide authored
Gateway, Team S1-G4, Saknee Fall 2019 Member of Gateway, Team S1-G4, Saknee Fall 2019
GCC-SAKNEE-F19S1G4
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 17
All Time: 494
