Asus Q503UA-BSI5T17 RAM Replacement
  1. Asus Q503UA-BSI5T17 RAM Replacement, Battery Replacement: step 1, image 1 of 1
    • Flip the computer upside down. In order to ensure that the correct side is up, you should be able to read the sticker that indicates the serial number on the bottom.
  2. Asus Q503UA-BSI5T17 RAM Replacement: step 2, image 1 of 2 Asus Q503UA-BSI5T17 RAM Replacement: step 2, image 2 of 2
    • Remove the ten circled screws along the perimeter of the laptop with a Phillips #0 screwdriver.
  3. Asus Q503UA-BSI5T17 RAM Replacement: step 3, image 1 of 3 Asus Q503UA-BSI5T17 RAM Replacement: step 3, image 2 of 3 Asus Q503UA-BSI5T17 RAM Replacement: step 3, image 3 of 3
    • Starting from the top right corner, use a plastic prying tool to separate the cover from the laptop. Use light pressure to prevent the plastic from breaking.
    • You should feel the frame coming loose. If necessary, use spacers to keep the frame from locking back into place.
    • Repeat the above step around the laptop until you are able to lift the cover.
  4. Asus Q503UA-BSI5T17 RAM Replacement, RAM: step 4, image 1 of 1
    • Locate the RAM component. The RAM, in this case, can be characterized by its blue coloration and eight individual smaller black chips.
  5. Asus Q503UA-BSI5T17 RAM Replacement: step 5, image 1 of 1
    • Locate the two white locking mechanisms on the left and right sides of the RAM component. Once you've located them, proceed to push them away from the RAM component.
  6. Asus Q503UA-BSI5T17 RAM Replacement: step 6, image 1 of 1
    • Upon unlocking the mechanism, you should find that the component now pops up at an almost 45-degree angle. Lift it up gently and carefully.
  7. Asus Q503UA-BSI5T17 RAM Replacement: step 7, image 1 of 2 Asus Q503UA-BSI5T17 RAM Replacement: step 7, image 2 of 2
    • Now slide out the component gently and place it in a secure location.
Roberto Apodaca
342 Reputation
2 Guides authored
Gateway, Team S1-G4, Saknee Fall 2019 Member of Gateway, Team S1-G4, Saknee Fall 2019
GCC-SAKNEE-F19S1G4
4 Members
5 Guides authored
One Comment
There is only one RAM Slot available…. right?
bryll503 - Reply
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 19
All Time: 1,196
