Asus Q504UA-BHI5T13 Battery Replacement
  1. Asus Q504UA-BHI5T13 Battery Replacement, Back Panel: step 1, image 1 of 1
    • Ensure that the laptop is off so you do not shock yourself.
  2. Asus Q504UA-BHI5T13 Battery Replacement: step 2, image 1 of 1
    • Use the T5 Torx screwdriver to remove the ten 1mm screws located around the back cover.
  3. Asus Q504UA-BHI5T13 Battery Replacement: step 3, image 1 of 1
    • Remove the two rubber pads nearest to you using the metal spudger.
  4. Asus Q504UA-BHI5T13 Battery Replacement: step 4, image 1 of 1
    • Use the Phillips #0 screwdriver to remove the two 4mm screws that are under the rubber pads.
  5. Asus Q504UA-BHI5T13 Battery Replacement: step 5, image 1 of 1
    • Insert any of the plastic opening tools into the seam to separate the back cover (it is recommended to start at the corner of the hinges). If you did it right, then the cover should pop off.
    • Be careful as you may damage the tabs.
  6. Asus Q504UA-BHI5T13 Battery Replacement, Battery: step 6, image 1 of 1
    • Once the back cover is removed, have the laptop facing upside down with the hinges facing toward you.
  7. Asus Q504UA-BHI5T13 Battery Replacement: step 7, image 1 of 1
    • Use the Phillips #0 screwdriver to remove the five 4mm screws around the battery.
  8. Asus Q504UA-BHI5T13 Battery Replacement: step 8, image 1 of 2 Asus Q504UA-BHI5T13 Battery Replacement: step 8, image 2 of 2
    • Use the small plastic opening tool to remove the ZIF Connector on the right side of the battery.
  9. Asus Q504UA-BHI5T13 Battery Replacement: step 9, image 1 of 2 Asus Q504UA-BHI5T13 Battery Replacement: step 9, image 2 of 2
    • Remove the battery from the device.
6 other people completed this guide.
Brielle
205 Reputation
1 Guide authored
USF Tampa, Team S10-G4, Thompson Fall 2017 Member of USF Tampa, Team S10-G4, Thompson Fall 2017
USFT-THOMPSON-F17S10G4
4 Members
5 Guides authored
One Comment
Anyone know where to purchase this battery. I’ve ordered off ebay only to get a non-fitting battery and have scoured the internet only to come up empty handed. Any help appreciated.
Rick Grinstead - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 36
All Time: 5,347
