Asus Q524U Wi-Fi Card Replacement
  1. Asus Q524U Wi-Fi Card Replacement, Back Panel: step 1, image 1 of 2 Asus Q524U Wi-Fi Card Replacement, Back Panel: step 1, image 2 of 2
    • Remove ten 3 mm screws using a Phillips #0 screwdriver.
  2. Asus Q524U Wi-Fi Card Replacement: step 2, image 1 of 1
    • Lift up the back panel and set it to the side.
  3. Asus Q524U Wi-Fi Card Replacement, Battery: step 3, image 1 of 2 Asus Q524U Wi-Fi Card Replacement, Battery: step 3, image 2 of 2
    • Using your fingers, grip onto both sides of the wire harness and push it upwards.
  4. Asus Q524U Wi-Fi Card Replacement: step 4, image 1 of 2 Asus Q524U Wi-Fi Card Replacement: step 4, image 2 of 2
    • Remove the five 3 mm screws holding the battery in place using a Phillips #0 screwdriver.
  5. Asus Q524U Wi-Fi Card Replacement: step 5, image 1 of 3 Asus Q524U Wi-Fi Card Replacement: step 5, image 2 of 3 Asus Q524U Wi-Fi Card Replacement: step 5, image 3 of 3
    • Tilt the small black tab up which will allow the blue tape to be slid out.
  6. Asus Q524U Wi-Fi Card Replacement: step 6, image 1 of 1
    • Simply lift the battery up and out of its holding area.
  7. Asus Q524U Wi-Fi Card Replacement, Wi-Fi Card: step 7, image 1 of 2 Asus Q524U Wi-Fi Card Replacement, Wi-Fi Card: step 7, image 2 of 2
    • Disconnect the black and white wires by pulling them up.
  8. Asus Q524U Wi-Fi Card Replacement: step 8, image 1 of 2 Asus Q524U Wi-Fi Card Replacement: step 8, image 2 of 2
    • Unscrew the single 3 mm screw using a Phillips #0 screwdriver.
  9. Asus Q524U Wi-Fi Card Replacement: step 9, image 1 of 2 Asus Q524U Wi-Fi Card Replacement: step 9, image 2 of 2
    • Slide the Wi-Fi card out of its slot.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 76
