Asus Q525U Hard Drive Replacement
  1. Asus Q525U Hard Drive Replacement, Back Cover: step 1, image 1 of 3 Asus Q525U Hard Drive Replacement, Back Cover: step 1, image 2 of 3 Asus Q525U Hard Drive Replacement, Back Cover: step 1, image 3 of 3
    • Begin by powering off the device and flipping the device over.
    • Carefully remove the two longer 9.5 mm screws on the corners with a Phillips #1 screwdriver.
    • Remove the eight 7.5 mm Phillips #1 screws on the back of the device.
  2. Asus Q525U Hard Drive Replacement: step 2, image 1 of 3 Asus Q525U Hard Drive Replacement: step 2, image 2 of 3 Asus Q525U Hard Drive Replacement: step 2, image 3 of 3
    • Use an opening pick to separate the back cover from the device.
    • For easiest removal, begin by prying at one of the front corners and sliding the tool under the cover in a counter-clockwise motion (to the left) toward the laptop hinge.
  3. Asus Q525U Hard Drive Replacement: step 3, image 1 of 3 Asus Q525U Hard Drive Replacement: step 3, image 2 of 3 Asus Q525U Hard Drive Replacement: step 3, image 3 of 3
    • Once the cover has been separated from the device, carefully lift the back cover off the device (begin by lifting from the front of the cover first).
    • The back cover should be easily removable, allowing full access to all of the internal components.
  4. Asus Q525U Hard Drive Replacement, Hard Drive: step 4, image 1 of 1
    • The hard drive is located to the left of the battery and below the motherboard.
  5. Asus Q525U Hard Drive Replacement: step 5, image 1 of 2 Asus Q525U Hard Drive Replacement: step 5, image 2 of 2
    • Remove the two 4 mm Phillips #1 screws which are holding the hard drive cover in place.
  6. Asus Q525U Hard Drive Replacement: step 6, image 1 of 2 Asus Q525U Hard Drive Replacement: step 6, image 2 of 2
    • The hard drive cover is now easily accessible.
    • Lift the cover off, exposing the hard drive underneath [this laptop is missing its hard drive].
    • If replacing the hard drive, lift it up on the right side slightly and pull it from the connecter on the left.
Stewart Crandall
550 Reputation
5 Guides authored
Clemson, Team 2-5, Hunter Spring 2022 Member of Clemson, Team 2-5, Hunter Spring 2022
CLEM-HUNTER-S22S2G5
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 60
All Time: 2,033
