Asus Q534U Motherboard Replacement
  1. Asus Q534U Motherboard Replacement, Back Case: step 1, image 1 of 3 Asus Q534U Motherboard Replacement, Back Case: step 1, image 2 of 3 Asus Q534U Motherboard Replacement, Back Case: step 1, image 3 of 3
    • Remove ten screws with the T5 driver.
    • Use the opening tool to carefully pry off the back case.
  2. Asus Q534U Motherboard Replacement, CPU Fan/Heat Sink: step 2, image 1 of 2 Asus Q534U Motherboard Replacement, CPU Fan/Heat Sink: step 2, image 2 of 2
    • Using the iFixit opening tool, gently pry the CPU fan connector out of the socket.
  3. Asus Q534U Motherboard Replacement: step 3, image 1 of 2 Asus Q534U Motherboard Replacement: step 3, image 2 of 2
    • Move the black cable located around the CPU fan out of the holder.
    • Remove the following 9 screws:
    • Three Phillips screws
    • Six Phillips screws
    • Make sure not to mix up both types of screws.
    • Gently pull vertically on the CPU fan/ heat sink assembly until it is free.
    • Before placing a new CPU fan/heat sink assembly, the CPU and GPU surfaces must be cleaned off and thermal compound must be reapplied.
  4. Asus Q534U Motherboard Replacement, Hard Drive: step 4, image 1 of 2 Asus Q534U Motherboard Replacement, Hard Drive: step 4, image 2 of 2
    • Remove four screws with the Phillips #00 screwdriver.
  5. Asus Q534U Motherboard Replacement: step 5, image 1 of 2 Asus Q534U Motherboard Replacement: step 5, image 2 of 2
    • Gently lift the hard disk out using the black tab.
  6. Asus Q534U Motherboard Replacement: step 6, image 1 of 1
    • Using a Phillips #00 screwdriver remove the four screws of the metal casing
    • Remove the hard disk from the metal casing
  7. Asus Q534U Motherboard Replacement, Motherboard: step 7, image 1 of 3 Asus Q534U Motherboard Replacement, Motherboard: step 7, image 2 of 3 Asus Q534U Motherboard Replacement, Motherboard: step 7, image 3 of 3
    • Disconnect the four marked cables connectors at the sockets.
  8. Asus Q534U Motherboard Replacement: step 8, image 1 of 3 Asus Q534U Motherboard Replacement: step 8, image 2 of 3 Asus Q534U Motherboard Replacement: step 8, image 3 of 3
    • Lift the connecting ports up prior to removing the connectors.
  9. Asus Q534U Motherboard Replacement: step 9, image 1 of 3 Asus Q534U Motherboard Replacement: step 9, image 2 of 3 Asus Q534U Motherboard Replacement: step 9, image 3 of 3
    • Remove the screws holding the hinges down on both sides of the device.
    • A pry tool might be needed to lift the hinge.
  10. Asus Q534U Motherboard Replacement: step 10, image 1 of 1
    • Remove nine, 3.2 mm screws to fully release motherboard.
2 other people completed this guide.
Jacob Pauker
228 Reputation
2 Guides authored
IUPUI, Team S1-G9, Hovde Fall 2019 Member of IUPUI, Team S1-G9, Hovde Fall 2019
IUPUI-HOVDE-F19S1G9
4 Members
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 22
All Time: 1,945
