Asus Q534U Wi-fi card Replacement
  1. Asus Q534U Wi-fi card Replacement, Back Case Removal: step 1, image 1 of 1
    • Make sure the device is turned off and unplugged from the charger.
    • Use a T5 screwdriver to remove all 10 screws that secure the bottom cover.
    • Pull off the back cover of the laptop.
    • A pry tool may be needed to pull off the back cover.
  2. Asus Q534U Wi-fi card Replacement: step 2, image 1 of 2 Asus Q534U Wi-fi card Replacement: step 2, image 2 of 2
    • Wedge an opening tool under the battery's bundled cable connector, and gently pry the connector up and to disconnect the battery.
  3. Asus Q534U Wi-fi card Replacement: step 3, image 1 of 2 Asus Q534U Wi-fi card Replacement: step 3, image 2 of 2
    • Lift up the black tab next to the silver ribbon cable.
    • Pull lightly on the blue tabs until the silver cable is free.
  4. Asus Q534U Wi-fi card Replacement: step 4, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the 5 marked screws.
    • Gently remove the battery.
    • Do not bend or puncture the laptop's lithium-polymer pattery.
  5. Asus Q534U Wi-fi card Replacement, Wi-Fi card: step 5, image 1 of 1
    • Disconnect the WiFi antenna cables by gently pulling them in an upwards motion.
    • Needle nose pliers can be used as a detaching tool.
  6. Asus Q534U Wi-fi card Replacement: step 6, image 1 of 1
    • Using a Phillips #0 screwdriver, remove the screw holding the WiFi card down.
    • Pull the WiFi card out of the socket toward the fan housing.
Eric Okoko
327 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 19
All Time: 2,848
