Asus Q550LF-BBI7T07 Disc Drive Replacement
  1. Asus Q550LF-BBI7T07 Disc Drive Replacement, Battery: step 1, image 1 of 2 Asus Q550LF-BBI7T07 Disc Drive Replacement, Battery: step 1, image 2 of 2
    • Use a T4 Torx screwdriver head to remove the ten 4mm Torx head screws on the bottom of the laptop.
  2. Asus Q550LF-BBI7T07 Disc Drive Replacement: step 2, image 1 of 2 Asus Q550LF-BBI7T07 Disc Drive Replacement: step 2, image 2 of 2
    • Use an opening tool to pry open the rear cover. Lift the cover off and away from the board.
  3. Asus Q550LF-BBI7T07 Disc Drive Replacement: step 3, image 1 of 2 Asus Q550LF-BBI7T07 Disc Drive Replacement: step 3, image 2 of 2
    • Use a Phillips #0 screwdriver head to remove the three black 7mm Phillips head screws that hold the battery in place.
  4. Asus Q550LF-BBI7T07 Disc Drive Replacement: step 4, image 1 of 2 Asus Q550LF-BBI7T07 Disc Drive Replacement: step 4, image 2 of 2
    • Once the screws have been removed, gently lift the battery out.
  5. Asus Q550LF-BBI7T07 Disc Drive Replacement, Hard Drive: step 5, image 1 of 2 Asus Q550LF-BBI7T07 Disc Drive Replacement, Hard Drive: step 5, image 2 of 2
    • Use the Phillips #0 Screwdriver to unscrew the four silver 5mm screws.
  6. Asus Q550LF-BBI7T07 Disc Drive Replacement: step 6, image 1 of 2 Asus Q550LF-BBI7T07 Disc Drive Replacement: step 6, image 2 of 2
    • Gently disconnect the Hard Drive from the connector cable. Lift it out and remove it.
  7. Asus Q550LF-BBI7T07 Disc Drive Replacement, Disc Drive: step 7, image 1 of 2 Asus Q550LF-BBI7T07 Disc Drive Replacement, Disc Drive: step 7, image 2 of 2
    • Use the Phillips #0 screwdriver to remove the two 7mm Phillips head screws from the metal disc drive holder.
  8. Asus Q550LF-BBI7T07 Disc Drive Replacement: step 8, image 1 of 1
    • Lift the metal disc drive holder off of the disc drive to remove it.
  9. Asus Q550LF-BBI7T07 Disc Drive Replacement: step 9, image 1 of 2 Asus Q550LF-BBI7T07 Disc Drive Replacement: step 9, image 2 of 2
    • Use the Phillips #0 screwdriver to unscrew the one silver 5mm Phillips head screw that connects the disc drive to the motherboard.
  10. Asus Q550LF-BBI7T07 Disc Drive Replacement: step 10, image 1 of 2 Asus Q550LF-BBI7T07 Disc Drive Replacement: step 10, image 2 of 2
    • Slowly slide out the disc drive, keeping it level, to remove it.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 440
