Asus Q550LF-BBI7T07 Hard Drive Replacement
  1. Asus Q550LF-BBI7T07 Hard Drive Replacement, Battery: step 1, image 1 of 2 Asus Q550LF-BBI7T07 Hard Drive Replacement, Battery: step 1, image 2 of 2
    • Use a T4 Torx screwdriver head to remove the ten 4mm Torx head screws on the bottom of the laptop.
  2. Asus Q550LF-BBI7T07 Hard Drive Replacement: step 2, image 1 of 2 Asus Q550LF-BBI7T07 Hard Drive Replacement: step 2, image 2 of 2
    • Use an opening tool to pry open the rear cover. Lift the cover off and away from the board.
  3. Asus Q550LF-BBI7T07 Hard Drive Replacement: step 3, image 1 of 2 Asus Q550LF-BBI7T07 Hard Drive Replacement: step 3, image 2 of 2
    • Use a Phillips #0 screwdriver head to remove the three black 7mm Phillips head screws that hold the battery in place.
  4. Asus Q550LF-BBI7T07 Hard Drive Replacement: step 4, image 1 of 2 Asus Q550LF-BBI7T07 Hard Drive Replacement: step 4, image 2 of 2
    • Once the screws have been removed, gently lift the battery out.
  5. Asus Q550LF-BBI7T07 Hard Drive Replacement, Hard Drive: step 5, image 1 of 2 Asus Q550LF-BBI7T07 Hard Drive Replacement, Hard Drive: step 5, image 2 of 2
    • Use the Phillips #0 Screwdriver to unscrew the four silver 5mm screws.
  6. Asus Q550LF-BBI7T07 Hard Drive Replacement: step 6, image 1 of 2 Asus Q550LF-BBI7T07 Hard Drive Replacement: step 6, image 2 of 2
    • Gently disconnect the Hard Drive from the connector cable. Lift it out and remove it.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 1,623
