Asus Q550LF-BBI7T07 RAM Replacement
  1. Asus Q550LF-BBI7T07 RAM Replacement, Battery: step 1, image 1 of 2 Asus Q550LF-BBI7T07 RAM Replacement, Battery: step 1, image 2 of 2
    • Use a T4 Torx screwdriver head to remove the ten 4mm Torx head screws on the bottom of the laptop.
  2. Asus Q550LF-BBI7T07 RAM Replacement: step 2, image 1 of 2 Asus Q550LF-BBI7T07 RAM Replacement: step 2, image 2 of 2
    • Use an opening tool to pry open the rear cover. Lift the cover off and away from the board.
  3. Asus Q550LF-BBI7T07 RAM Replacement: step 3, image 1 of 2 Asus Q550LF-BBI7T07 RAM Replacement: step 3, image 2 of 2
    • Use a Phillips #0 screwdriver head to remove the three black 7mm Phillips head screws that hold the battery in place.
  4. Asus Q550LF-BBI7T07 RAM Replacement: step 4, image 1 of 2 Asus Q550LF-BBI7T07 RAM Replacement: step 4, image 2 of 2
    • Once the screws have been removed, gently lift the battery out.
  5. Asus Q550LF-BBI7T07 RAM Replacement, RAM: step 5, image 1 of 3 Asus Q550LF-BBI7T07 RAM Replacement, RAM: step 5, image 2 of 3 Asus Q550LF-BBI7T07 RAM Replacement, RAM: step 5, image 3 of 3
    • Push both metal tabs away from each other on each side of the RAM farthest from battery so that the RAM will pop up.
  6. Asus Q550LF-BBI7T07 RAM Replacement: step 6, image 1 of 1
    • Pull out first RAM chip.
  7. Asus Q550LF-BBI7T07 RAM Replacement: step 7, image 1 of 1
    • Push both metal tabs away from each other on each side of the RAM closest to the battery so that the second RAM will pop up.
  8. Asus Q550LF-BBI7T07 RAM Replacement: step 8, image 1 of 2 Asus Q550LF-BBI7T07 RAM Replacement: step 8, image 2 of 2
    • Pull out second RAM chip.
4 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 636
