Asus Q551L Battery Replacement
  1. Asus Q551L Battery Replacement, Back Panel: step 1, image 1 of 2 Asus Q551L Battery Replacement, Back Panel: step 1, image 2 of 2
    • Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 , two of them are 0.0793 JIS #0.
  2. Asus Q551L Battery Replacement: step 2, image 1 of 1
    • Use the plastic opening tool to pry the back panel off the base of the laptop.
  3. Asus Q551L Battery Replacement, Battery: step 3, image 1 of 2 Asus Q551L Battery Replacement, Battery: step 3, image 2 of 2
    • Unscrew the four screws to remove the battery.
  4. Asus Q551L Battery Replacement: step 4, image 1 of 2 Asus Q551L Battery Replacement: step 4, image 2 of 2
    • Un-clip both wire clips on the upper and right side of the battery.
    • Lift the battery out of the device.
4 other people completed this guide.
One Comment
Is there a part to order if the solder gives from the mother board connection peice. My cable came up from the board with connection still attached
wolf brown - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 44
All Time: 7,098
