Asus Q551L Repair Optical Drive Replacement
  1. Asus Q551L Repair Optical Drive Replacement, Back Panel: step 1, image 1 of 2 Asus Q551L Repair Optical Drive Replacement, Back Panel: step 1, image 2 of 2
    • Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 , two of them are 0.0793 JIS #0.
  2. Asus Q551L Repair Optical Drive Replacement: step 2, image 1 of 1
    • Use the plastic opening tool to pry the back panel off the base of the laptop.
  3. Asus Q551L Repair Optical Drive Replacement, Optical Drive: step 3, image 1 of 3 Asus Q551L Repair Optical Drive Replacement, Optical Drive: step 3, image 2 of 3 Asus Q551L Repair Optical Drive Replacement, Optical Drive: step 3, image 3 of 3
    • Lift up the sticker that sticks between the motherboard and the optical drive. Then, unscrew the one screw where it is marked and slide it out gently.
    • Watch out for the wires around the optical drive.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 680
