Asus Q551L Screen Replacement
  1. Asus Q551L Screen Replacement, Back Panel: step 1, image 1 of 2 Asus Q551L Screen Replacement, Back Panel: step 1, image 2 of 2
    • Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 , two of them are 0.0793 JIS #0.
  2. Asus Q551L Screen Replacement: step 2, image 1 of 1
    • Use the plastic opening tool to pry the back panel off the base of the laptop.
  3. Asus Q551L Screen Replacement, Battery: step 3, image 1 of 2 Asus Q551L Screen Replacement, Battery: step 3, image 2 of 2
    • Unscrew the four screws to remove the battery.
  4. Asus Q551L Screen Replacement: step 4, image 1 of 2 Asus Q551L Screen Replacement: step 4, image 2 of 2
    • Un-clip both wire clips on the upper and right side of the battery.
    • Lift the battery out of the device.
  5. Asus Q551L Screen Replacement, Screen: step 5, image 1 of 2 Asus Q551L Screen Replacement, Screen: step 5, image 2 of 2
    • Use the metal spudger to gently lift the two plastic squares off the screen.
  6. Asus Q551L Screen Replacement: step 6, image 1 of 2 Asus Q551L Screen Replacement: step 6, image 2 of 2
    • Unscrew the two PH0 screws and set them aside.
  7. Asus Q551L Screen Replacement: step 7, image 1 of 1
    • Use the plastic opening tool to pry the front edges of the screen off of the back.
  8. Asus Q551L Screen Replacement: step 8, image 1 of 1
    • Take off the tapes.
    • Gently pry the LCD from the front frame.
4 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 12
All Time: 3,337
