Asus Q552UB-BHI7T12 Battery Replacement
  1. Asus Q552UB-BHI7T12 Battery Replacement, Battery: step 1, image 1 of 1
    • Remove all ten screws on the back of the laptop to remove the cover.
    • Remove the cover.
  2. Asus Q552UB-BHI7T12 Battery Replacement: step 2, image 1 of 2 Asus Q552UB-BHI7T12 Battery Replacement: step 2, image 2 of 2
    • Disconnect the wires at the top of the battery by lifting on the tabs protruding out of the plastic frame.
  3. Asus Q552UB-BHI7T12 Battery Replacement: step 3, image 1 of 1
    • Remove the four screws holding the battery in place, two on top and one on each side.
  4. Asus Q552UB-BHI7T12 Battery Replacement: step 4, image 1 of 1
    • Gently lift out the battery by the side closest to the motherboard first.
    • Be careful of any extra wires that may have attached itself to the battery.
One Comment
Greetings I have tried to pull the battery out but i have issues making it go out of the place where it clicks, could you make a detailed video on how to safely remove that part without breaking the wires or the soldering on the board???
jorgealanhurtado95 - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 3,322
