Asus Q552UB-BHI7T12 Screen Replacement
  1. Asus Q552UB-BHI7T12 Screen Replacement, Screen: step 1, image 1 of 2 Asus Q552UB-BHI7T12 Screen Replacement, Screen: step 1, image 2 of 2
    • Remove the two screw covers by hand or by using the pointed end of a spudger.
  2. Asus Q552UB-BHI7T12 Screen Replacement: step 2, image 1 of 1
    • Remove both screws with a Phillips head screwdriver.
  3. Asus Q552UB-BHI7T12 Screen Replacement: step 3, image 1 of 2 Asus Q552UB-BHI7T12 Screen Replacement: step 3, image 2 of 2
    • Wedge an opening tool between the two halves of the screen.
    • Keep the two latches together and go completely around the screen to release all the latches.
  4. Asus Q552UB-BHI7T12 Screen Replacement: step 4, image 1 of 2 Asus Q552UB-BHI7T12 Screen Replacement: step 4, image 2 of 2
    • Separate the two parts of the screen.
  5. Asus Q552UB-BHI7T12 Screen Replacement: step 5, image 1 of 1
    • Remove any tape that is holding the screen in place.
  6. Asus Q552UB-BHI7T12 Screen Replacement: step 6, image 1 of 2 Asus Q552UB-BHI7T12 Screen Replacement: step 6, image 2 of 2
    • Use an opening tool to lift out the screen after all the tape is removed.
    • The screen may be stuck due to any tape or any remaining glue.
  7. Asus Q552UB-BHI7T12 Screen Replacement: step 7, image 1 of 1
    • Pull the screen horizontally away to remove the last cable attached to the screen.
Follow these instructions in reverse order to reassemble your device.
2 other people completed this guide.
2 Comments
Can you show the connection on motherboard for LCD cable?
Bustelo Pilon - Reply
Does anyone know where I can get this same model replacement?
Anthony C - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 967
