Asus R510CA-OB01 Display Replacement
  1. Asus R510CA-OB01 Display Replacement, Display: step 1, image 1 of 3 Asus R510CA-OB01 Display Replacement, Display: step 1, image 2 of 3 Asus R510CA-OB01 Display Replacement, Display: step 1, image 3 of 3
    • Open the device.
    • Remove the black plastic squares on each side with a spudger.
  2. Asus R510CA-OB01 Display Replacement: step 2, image 1 of 2 Asus R510CA-OB01 Display Replacement: step 2, image 2 of 2
    • Remove the two 5mm screws at each bottom corner of the display using a Phillips #0 screwdriver.
  3. Asus R510CA-OB01 Display Replacement: step 3, image 1 of 3 Asus R510CA-OB01 Display Replacement: step 3, image 2 of 3 Asus R510CA-OB01 Display Replacement: step 3, image 3 of 3
    • After the two screws are removed, use a plastic opening tool to remove the black cover around the screen.
  4. Asus R510CA-OB01 Display Replacement: step 4, image 1 of 3 Asus R510CA-OB01 Display Replacement: step 4, image 2 of 3 Asus R510CA-OB01 Display Replacement: step 4, image 3 of 3
    • Remove the four 5mm screws that attach the screen with a Philips #0 screwdriver.
  5. Asus R510CA-OB01 Display Replacement: step 5, image 1 of 2 Asus R510CA-OB01 Display Replacement: step 5, image 2 of 2
    • Lift up the screen from the back of the laptop and then you will see a cable connected to the screen.
    • You can simply disconnect the cable and insert a new screen.
Blanche Pinto
437 Reputation
4 Guides authored
USF Tampa, Team S3-G4, Nance Fall 2017 Member of USF Tampa, Team S3-G4, Nance Fall 2017
USFT-NANCE-F17S3G4
2 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 511
