Asus R510CA-OB01 Hard Drive Replacement
  1. Asus R510CA-OB01 Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
    • Shut down the computer and disconnect all external devices connected to it.
    • Turn the computer so that it is upside down. Position the computer with the front towards you.
  2. Asus R510CA-OB01 Hard Drive Replacement: step 2, image 1 of 2 Asus R510CA-OB01 Hard Drive Replacement: step 2, image 2 of 2
    • Loosen the two 12 mm screws on the bottom panel of your device using a Phillips size 0 bit.
  3. Asus R510CA-OB01 Hard Drive Replacement: step 3, image 1 of 3 Asus R510CA-OB01 Hard Drive Replacement: step 3, image 2 of 3 Asus R510CA-OB01 Hard Drive Replacement: step 3, image 3 of 3
    • Use the grips to slide the panel off.
    • Remove the panel by lifting it off the device.
  4. Asus R510CA-OB01 Hard Drive Replacement: step 4, image 1 of 3 Asus R510CA-OB01 Hard Drive Replacement: step 4, image 2 of 3 Asus R510CA-OB01 Hard Drive Replacement: step 4, image 3 of 3
    • Loosen the three 5 mm screws holding down the hard drive using a Phillips #00 bit.
  5. Asus R510CA-OB01 Hard Drive Replacement: step 5, image 1 of 2 Asus R510CA-OB01 Hard Drive Replacement: step 5, image 2 of 2
    • Slide the casing (hard drive bay) for the hard drive to the left.
    • Lift it to remove it from the device.
Blanche Pinto
437 Reputation
4 Guides authored
USF Tampa, Team S3-G4, Nance Fall 2017 Member of USF Tampa, Team S3-G4, Nance Fall 2017
USFT-NANCE-F17S3G4
2 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 634
