Asus R541UA-RB51 Hard Drive Replacement
  1. Asus R541UA-RB51 Hard Drive Replacement, Keyboard: step 1, image 1 of 3 Asus R541UA-RB51 Hard Drive Replacement, Keyboard: step 1, image 2 of 3 Asus R541UA-RB51 Hard Drive Replacement, Keyboard: step 1, image 3 of 3
    • Flip the laptop over so that the back panel is facing up.
    • Carefully remove the eight 5.7mm screws on the back panel using a Phillips #1 screwdriver.
  2. Asus R541UA-RB51 Hard Drive Replacement: step 2, image 1 of 2 Asus R541UA-RB51 Hard Drive Replacement: step 2, image 2 of 2
    • Turn the laptop upright and flip the screen open.
    • Using the plastic opening tool, gently pry the keyboard panel off of the base.
  3. Asus R541UA-RB51 Hard Drive Replacement: step 3, image 1 of 2 Asus R541UA-RB51 Hard Drive Replacement: step 3, image 2 of 2
    • Gently raise the keyboard from the base enough to access the underside.
    • Gently pull up on the locking tab to release the ribbon cable. This should take no force to complete.
    • Remove the keyboard.
  4. Asus R541UA-RB51 Hard Drive Replacement, Hard Drive: step 4, image 1 of 2 Asus R541UA-RB51 Hard Drive Replacement, Hard Drive: step 4, image 2 of 2
    • Locate the hard drive in the lower right hand corner in the computer. This device did not have a hard drive so a piece of cardboard was used as a substitute.
    • Remove the two 5.7 mm screws from the base. Use a Phillips #1 screwdriver to remove the screws. Lift up to remove the hard drive.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 688
