Asus R558UQ-DM513D SSD Replacement
  1. Asus R558UQ-DM513D SSD Replacement, HDD (Hard Disk Drive): step 1, image 1 of 1
    • Using the Phillips #0 screwdriver, remove the single 5 mm screw and remove the RAM access panel.
    • Remove the ten 5 mm screws using the same Phillips #0 screwdriver.
  2. Asus R558UQ-DM513D SSD Replacement: step 2, image 1 of 1
    • Remove two 2 mm hidden screws using the Phillips #0 screwdriver.
  3. Asus R558UQ-DM513D SSD Replacement: step 3, image 1 of 1
    • Remove the back cover of the laptop to expose the inner components.
  4. Asus R558UQ-DM513D SSD Replacement: step 4, image 1 of 1
    • Using the Phillips #0 screwdriver, remove the two 2 mm screws holding the HDD in place.
  5. Asus R558UQ-DM513D SSD Replacement: step 5, image 1 of 1
    • Gently take the left-side board containing the ports by simply sliding it in and taking it out while still connected to the wire.
  6. Asus R558UQ-DM513D SSD Replacement: step 6, image 1 of 1
    • Slide the HDD out.
Deepanker Seth
133 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 30
All Time: 1,501
