Asus R752L Battery Replacement
  1. Asus R752L Battery Replacement, Remove the keyboard: step 1, image 1 of 3 Asus R752L Battery Replacement, Remove the keyboard: step 1, image 2 of 3 Asus R752L Battery Replacement, Remove the keyboard: step 1, image 3 of 3
    • The first step to remove the keyboard is to remove 8 Philips screws on the bottom of the laptop.
    • Step two is to carefully pry the keyboard loose from the bottom of the laptop. Be careful while lifting the keyboard since it is still wired to the motherboard.
    • Lastly disconnect both the touchpad and the keyboard wires. Now the keyboard can be lifted completely out of the way.
  2. Asus R752L Battery Replacement, Remove the old battery: step 2, image 1 of 3 Asus R752L Battery Replacement, Remove the old battery: step 2, image 2 of 3 Asus R752L Battery Replacement, Remove the old battery: step 2, image 3 of 3
    • This should be the view right now. The battery is located near the screen.
    • Second, disconnect the wires between the battery and the motherboard.
    • Next, unscrew the two Philips screws holding the battery in place.
    • By tilting the battery towards the screen the battery can be lifted out of the laptop.
  3. Asus R752L Battery Replacement, Install new battery: step 3, image 1 of 1
    • Place the new battery where the old one was located tilted towards the screen.
    • Tilt the battery staight and fasten the two Philips screws holding the battery in place.
    • Reattach the wires to the motherboard.
    • Reconnect the keyboard and touchpad connectors.
    • Fix the keyboard to the bottom of the laptop by gently pressing the together.
    • Screw the 8 Philips screws back into the bottom of the laptop and you're done.
Om het apparaat weer te monteren, volg je deze instructies in omgekeerde volgorde.
2 other people completed this guide.
Jonathan Stek
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 57
All Time: 1,141
