Asus ROG Ally Right Thumbstick Replacement
Spencer Day
Spencer Day and 4 other contributors
Last updated on March 5, 2025
30 - 45 minutes
Moderate
Introduction
Go to step 1
Follow this guide to replace a broken or drifting right thumbstick (a.k.a. joystick) in your Asus ROG Ally. Since the thumbstick module is not soldered to the board—a win for repair—you can also use this guide to replace the right thumbstick board.
If you're experiencing drift, unusual or unexpected movements, no movement at all, or loose movement, it may be time to replace your right thumbstick.
Parts
Tools
Show more…
  1. Asus ROG Ally Right Thumbstick Replacement, Prepare your device for disassembly: step 1, image 1 of 3 Asus ROG Ally Right Thumbstick Replacement, Prepare your device for disassembly: step 1, image 2 of 3 Asus ROG Ally Right Thumbstick Replacement, Prepare your device for disassembly: step 1, image 3 of 3
    • Let your device's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
    • Completely power off your device and unplug all cables.
    • Consider laying your device on a soft cloth to prevent scratching or damaging the screen during your repair.
  2. Asus ROG Ally Right Thumbstick Replacement, Unfasten the back cover: step 2, image 1 of 2 Asus ROG Ally Right Thumbstick Replacement, Unfasten the back cover: step 2, image 2 of 2
    Tool used on this step:
    FixMat
    $36.95
    • Use a Phillips #0 screwdriver to remove the five 17.2 mm‑long screws securing the top edge and bottom corners of the back cover.
    • Use a Phillips #0 screwdriver to fully loosen the remaining captive screw at the center of the bottom edge. This should create a small gap between the back cover and chassis.
    • Don't try to remove this screw.
  3. Asus ROG Ally Right Thumbstick Replacement, Insert an opening pick: step 3, image 1 of 3 Asus ROG Ally Right Thumbstick Replacement, Insert an opening pick: step 3, image 2 of 3 Asus ROG Ally Right Thumbstick Replacement, Insert an opening pick: step 3, image 3 of 3
    • Insert the flat edge of an opening pick between the bottom edge of the back cover and chassis, near the captive screw.
    • Angle the pick upward and push it under the back cover.
  4. Asus ROG Ally Right Thumbstick Replacement, Release the back cover's clips: step 4, image 1 of 3 Asus ROG Ally Right Thumbstick Replacement, Release the back cover's clips: step 4, image 2 of 3 Asus ROG Ally Right Thumbstick Replacement, Release the back cover's clips: step 4, image 3 of 3
    • Plastic clips secure the perimeter of the back cover. You should feel and hear them release during this step.
    • Slide the opening pick along the bottom edge and around the corners of the back cover to release the clips securing it.
    • Keep the pick at an upward angle under the back cover to help release the clips.
  5. Asus ROG Ally Right Thumbstick Replacement, Remove the back cover: step 5, image 1 of 3 Asus ROG Ally Right Thumbstick Replacement, Remove the back cover: step 5, image 2 of 3 Asus ROG Ally Right Thumbstick Replacement, Remove the back cover: step 5, image 3 of 3
    • Lift the bottom edge of the back cover off the chassis to release the remaining clips.
    • Remove the back cover.
    • During reassembly, lay the back cover onto your device and firmly push down around the perimeter to engage the clips.
  6. Asus ROG Ally Right Thumbstick Replacement, Remove the plastic cover: step 6, image 1 of 3 Asus ROG Ally Right Thumbstick Replacement, Remove the plastic cover: step 6, image 2 of 3 Asus ROG Ally Right Thumbstick Replacement, Remove the plastic cover: step 6, image 3 of 3
    • Use your fingers to peel up and remove the black plastic cover between the fans.
    • Put the cover aside—you'll use it during reassembly.
  7. Asus ROG Ally Right Thumbstick Replacement, Unlatch the locking bar: step 7, image 1 of 3 Asus ROG Ally Right Thumbstick Replacement, Unlatch the locking bar: step 7, image 2 of 3 Asus ROG Ally Right Thumbstick Replacement, Unlatch the locking bar: step 7, image 3 of 3
    • A metal locking bar secures the top edge of the battery connector
    • Use the flat end of a spudger to gently push the locking bar away from the connector to unlatch it.
  8. Asus ROG Ally Right Thumbstick Replacement, Disconnect the battery: step 8, image 1 of 3 Asus ROG Ally Right Thumbstick Replacement, Disconnect the battery: step 8, image 2 of 3 Asus ROG Ally Right Thumbstick Replacement, Disconnect the battery: step 8, image 3 of 3
    • Make sure the locking bar is not covering the battery connector at all, or you may damage the socket and the locking bar.
    • Insert the flat end of a spudger under the center of the battery connector.
    • Lift the connector straight up and out of its socket to disconnect the battery.
    • During reassembly, use your fingers or the flat end of a spudger to firmly push the connector onto its socket until it clicks into place.
  9. Asus ROG Ally Right Thumbstick Replacement, Disconnect the thumbstick interconnect cable: step 9, image 1 of 3 Asus ROG Ally Right Thumbstick Replacement, Disconnect the thumbstick interconnect cable: step 9, image 2 of 3 Asus ROG Ally Right Thumbstick Replacement, Disconnect the thumbstick interconnect cable: step 9, image 3 of 3
    • The right thumbstick will be on your left-hand side since your device is laying upside down.
    • Use a spudger or a clean fingernail to lift the locking flap on the thumbstick interconnect cable ZIF connector, located on the right thumbstick board.
    • Use tweezers to grip the cable's blue pull tab and pull the connector straight out of its socket.
  10. Asus ROG Ally Right Thumbstick Replacement, Disconnect the right thumbstick ring: step 10, image 1 of 3 Asus ROG Ally Right Thumbstick Replacement, Disconnect the right thumbstick ring: step 10, image 2 of 3 Asus ROG Ally Right Thumbstick Replacement, Disconnect the right thumbstick ring: step 10, image 3 of 3
    • Use the point of a spudger to lift the locking flap on the right thumbstick ring ZIF connector.
    • The black line on the ZIF connector cables mark the connection area. During reassembly, insert the cables into their sockets up to this line.
  11. Asus ROG Ally Right Thumbstick Replacement, Unfasten the right thumbstick assembly: step 11, image 1 of 3 Asus ROG Ally Right Thumbstick Replacement, Unfasten the right thumbstick assembly: step 11, image 2 of 3 Asus ROG Ally Right Thumbstick Replacement, Unfasten the right thumbstick assembly: step 11, image 3 of 3
    • Use a Phillips #00 screwdriver to remove the four 3.4 mm‑long screws securing the right thumbstick assembly.
    • During reassembly, keep the left edge of your device lifted while you tighten the screws so the thumbstick doesn't press against your work surface and pop out of place.
  12. Asus ROG Ally Right Thumbstick Replacement, Remove the right thumbstick assembly: step 12, image 1 of 3 Asus ROG Ally Right Thumbstick Replacement, Remove the right thumbstick assembly: step 12, image 2 of 3 Asus ROG Ally Right Thumbstick Replacement, Remove the right thumbstick assembly: step 12, image 3 of 3
    • Insert the flat end of a spudger between the bottom left edge of the thumbstick assembly and the chassis.
    • Pry up the thumbstick assembly and remove it.
    • During reassembly:
    • Orient the board over your device thumbstick side down.
    • Thread the thumbstick ring cable through its cutout on the board.
    • Lift the left edge of your device and push the thumbstick assembly firmly into place so the small circular cutouts on the left edge go over their alignment posts. The board should stay firmly in place.
  13. Asus ROG Ally Right Thumbstick Replacement, Reposition the right thumbstick assembly: step 13, image 1 of 1
    • Lay the assembly on a clean cloth with the thumbstick facing up.
  14. Asus ROG Ally Right Thumbstick Replacement, Remove the right thumbstick cover: step 14, image 1 of 2 Asus ROG Ally Right Thumbstick Replacement, Remove the right thumbstick cover: step 14, image 2 of 2
    • With one hand, firmly secure the thumbstick board.
    • With your free hand, pull the thumbstick cover straight up and off its module.
    • To install the thumbstick cover, rotate it on its module until it slides into place. Then firmly press down until the cover snaps into place or bottoms out.
  15. Asus ROG Ally Right Thumbstick Replacement, Lift the right thumbstick locking flap: step 15, image 1 of 2 Asus ROG Ally Right Thumbstick Replacement, Lift the right thumbstick locking flap: step 15, image 2 of 2
    • Use the point of a spudger to lift the locking flap on the thumbstick ZIF connector.
  16. Asus ROG Ally Right Thumbstick Replacement, Unfasten the right thumbstick: step 16, image 1 of 2 Asus ROG Ally Right Thumbstick Replacement, Unfasten the right thumbstick: step 16, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the two 3.4 mm‑long screws securing the thumbstick.
  17. Asus ROG Ally Right Thumbstick Replacement, Remove the right thumbstick: step 17, image 1 of 2 Asus ROG Ally Right Thumbstick Replacement, Remove the right thumbstick: step 17, image 2 of 2
    • Grab the thumbstick with your fingers and gently pull the cable out of its socket.
    • You're now left with the thumbstick and thumbstick board on their own.
    • After reassembling your device, follow this guide to calibrate your new thumbstick.
3 other people completed this guide.
Spencer Day
95,709 Reputation
662 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,547 Guides authored
0 Comments
Past 24 Hours: 28
Past 7 Days: 205
Past 30 Days: 974
All Time: 9,029
