Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement
  1. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement, Battery: step 1, image 1 of 3 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement, Battery: step 1, image 2 of 3 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement, Battery: step 1, image 3 of 3
    • With your right hand, push the latch completely up to where you can see the battery pop slightly up. Pick and pull at the tab with your left hand.
    • You can now fully remove the battery from the device.
  2. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement, Track Pad Buttons: step 2, image 1 of 2 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement, Track Pad Buttons: step 2, image 2 of 2
    • Remove the large flathead screw holding the back cover in place.
    • Pull the cover off by prying it open starting from the top center and moving outwards.
  3. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: step 3, image 1 of 2 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: step 3, image 2 of 2
    • Remove the eight short screws holding in the two metal covers near the bottom.
    • Remove the two metal covers.
  4. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: step 4, image 1 of 2 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: step 4, image 2 of 2
    • Remove the battery to access the screws under it.
    • Remove these 16 screws with a regular Phillips head screw-driver.
    • These Phillips head screws will require a longer bit or an extension.
  5. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: step 5, image 1 of 2 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: step 5, image 2 of 2
    • Flip the device back over.
    • Pull off the plastic cover behind the screen.
    • Remove the four Phillips head screws holding the screen in place.
  6. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: step 6, image 1 of 2 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: step 6, image 2 of 2
    • With the screen removed, pry the piece that has the keyboard and the track pad on it.
  7. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: step 7, image 1 of 2 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: step 7, image 2 of 2
    • Remove the two Phillips head screws holding the buttons in place.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 19
All Time: 415
