Asus ROG G750JM-BS17N23 Hard Drive Replacement
  1. Asus ROG G750JM-BS17N23 Hard Drive Replacement, Back Plate: step 1, image 1 of 1
    • With the computer upside down, lift up on the rubber cap on the back plate to access the captive Phillips #2 screw.
  2. Asus ROG G750JM-BS17N23 Hard Drive Replacement: step 2, image 1 of 1
    • Retract the Phillips #2 screw until the cover is loose.
    • The screw will not come all the way out.
  3. Asus ROG G750JM-BS17N23 Hard Drive Replacement: step 3, image 1 of 3 Asus ROG G750JM-BS17N23 Hard Drive Replacement: step 3, image 2 of 3 Asus ROG G750JM-BS17N23 Hard Drive Replacement: step 3, image 3 of 3
    • Pry around the edges of the plate using a plastic opening tool until the plate is removed.
  4. Asus ROG G750JM-BS17N23 Hard Drive Replacement, Hard Drive: step 4, image 1 of 1
    • To access the hard drive, remove the back plate.
  5. Asus ROG G750JM-BS17N23 Hard Drive Replacement: step 5, image 1 of 2 Asus ROG G750JM-BS17N23 Hard Drive Replacement: step 5, image 2 of 2
    • Remove the three 4mm Phillips #2 screws.
  6. Asus ROG G750JM-BS17N23 Hard Drive Replacement: step 6, image 1 of 2 Asus ROG G750JM-BS17N23 Hard Drive Replacement: step 6, image 2 of 2
    • Pull back on the tab on the hard drive shield until it is clear of the screw slots. Next pull the shield out.
  7. Asus ROG G750JM-BS17N23 Hard Drive Replacement: step 7, image 1 of 2 Asus ROG G750JM-BS17N23 Hard Drive Replacement: step 7, image 2 of 2
    • With the hard drive exposed, pull the hard drive away from the connection point and then remove the hard drive.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 492
