Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement
  1. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement, Soundbar/speaker: step 1, image 1 of 2 Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement, Soundbar/speaker: step 1, image 2 of 2
    • Using a plastic opening tool, remove the two rubber tabs circled in red.
  2. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: step 2, image 1 of 2 Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: step 2, image 2 of 2
    • Remove both of the 8mm Phillips #2 screws from these slots where the rubber caps were removed.
  3. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: step 3, image 1 of 2 Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: step 3, image 2 of 2
    • Slide the tab to pop the battery out of its holder.
    • Pull the battery out of its slot.
  4. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: step 4, image 1 of 2 Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: step 4, image 2 of 2
    • Remove the three 4mm Phillips #2 screws from the open battery slot as shown.
    • Remove the two 5mm Phillips #2 screws.
  5. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: step 5, image 1 of 3 Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: step 5, image 2 of 3 Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: step 5, image 3 of 3
    • Begin prying up on the plate as shown in the pictures.
  6. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: step 6, image 1 of 1
    • Detach the single connector using your plastic opening tool.
    • Remove the speaker bar.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 417
