Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement
  1. Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement, Remove the RAM access door: step 1, image 1 of 2 Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement, Remove the RAM access door: step 1, image 2 of 2
    • Use an opening tool to pry up the small rubber cover on the upper right corner of the RAM access door.
  2. Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement: step 2, image 1 of 1
    • Remove the 5.3 mm Phillips #00 screw securing the RAM access door.
    • This screw is held in the hole in the door with a washer and will not come out of the hole, even after you unscrew it.
  3. Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement: step 3, image 1 of 2 Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement: step 3, image 2 of 2
    • Insert the point of an opening pick in the seam near the top right corner of the RAM access door and gently pry the door up slightly.
    • The door is held in place by small clips around its edges. Pry until you feel the nearest clips release.
  4. Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement: step 4, image 1 of 3 Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement: step 4, image 2 of 3 Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement: step 4, image 3 of 3
    • Insert the wide edge of an opening pick into a new part of the seam between the door and the computer.
    • Pry the door up to release the clips closest to the pick.
    • Continue to slide the pick along the seam all the way around the door, prying as you go, until all the clips holding the door down have been released.
  5. Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement: step 5, image 1 of 1
    • Remove the RAM access door.
  6. Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement, Remove the optical drive: step 6, image 1 of 1
    • Remove the 5.2 mm Phillips #00 screw securing the optical drive.
  7. Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement: step 7, image 1 of 3 Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement: step 7, image 2 of 3 Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement: step 7, image 3 of 3
    • Insert an opening tool into the gap between the optical drive and the laptop.
    • Pry the optical drive straight out of the laptop.
    • Remove the optical drive.
  8. Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement, Remove the case screws: step 8, image 1 of 1
    • Use the point of a spudger to pry out eleven rubber plugs covering the screws on the bottom of the laptop.
    • Some plugs have a hole or notch into which you can insert the point of a spudger to more easily pry out the plugs.
  9. Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement: step 9, image 1 of 2 Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement: step 9, image 2 of 2
    • Remove 18 Phillips #00 screws of the following lengths:
    • Eight 8.8 mm screws
    • Seven 5.2 mm screws
    • Three screws
  10. Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement, Remove the battery cover: step 10, image 1 of 3 Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement, Remove the battery cover: step 10, image 2 of 3 Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement, Remove the battery cover: step 10, image 3 of 3
    • Flip the laptop right-side up.
    • Use an opening pick to pry the left and right edges of the battery cover away from the laptop enough that you can grip the cover with your fingers.
  11. Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement: step 11, image 1 of 2 Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement: step 11, image 2 of 2
    • Lift the battery cover straight up from the laptop.
    • Do not try to completely remove the cover yet, it is still tethered by a speaker cable.
  12. Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement, Disconnect the speaker cable: step 12, image 1 of 2 Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement, Disconnect the speaker cable: step 12, image 2 of 2
    • Pull the speaker connectors straight away from each other to disconnect the speaker cable.
    • Make sure the speaker cable is out of the way before you reinstall the battery cover.
  13. Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement, Remove the upper case assembly: step 13, image 1 of 3 Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement, Remove the upper case assembly: step 13, image 2 of 3 Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement, Remove the upper case assembly: step 13, image 3 of 3
    • Open the laptop's display to a 90° angle.
    • Use a spudger to pry against one of the screw tabs on the back of the upper case assembly.
    • Make sure to pry as close as possible to the base of the tab to avoid damaging the tab.
    • Repeat this procedure with the other tab.
    • The upper case assembly is held in place by small clips around its edges. In this step, pry each tab up until you feel the nearest clips release.
  14. Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement: step 14, image 1 of 2 Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement: step 14, image 2 of 2
    • Insert the flat end of a spudger in the gap between the laptop and the upper case assembly, near the display.
    • If there's not a big enough gap, repeat the previous step until you have space to insert the spudger.
  15. Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement: step 15, image 1 of 3 Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement: step 15, image 2 of 3 Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement: step 15, image 3 of 3
    • Slide the spudger along each edge of the upper case assembly, prying and releasing clips as you go.
  16. Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement: step 16, image 1 of 3 Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement: step 16, image 2 of 3 Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement: step 16, image 3 of 3
    • When all the clips securing the upper case assembly have been released, lift the assembly slightly and slide it down, away from the display, about an inch.
    • Do not attempt to remove the assembly yet. It is still attached to the laptop by four cables.
  17. Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement: step 17, image 1 of 3 Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement: step 17, image 2 of 3 Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement: step 17, image 3 of 3
    • Use the tip of a spudger to flip up the small locking flap of the keyboard backlight cable ZIF connector.
    • Be sure to pry up on the hinged flap, not the connector socket.
    • Gently pull the cable out of its socket.
  18. Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement: step 18, image 1 of 3 Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement: step 18, image 2 of 3 Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement: step 18, image 3 of 3
    • Repeat the previous step for the keyboard, trackpad buttons, and trackpad cables held in place by ZIF connectors.
  19. Asus ROG G751JL-BB17T29 Upper Case Assembly Replacement: step 19, image 1 of 1
    • Remove the upper case assembly.
Adam O'Camb
198,503 Reputation
416 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 15
All Time: 1,710
